TV Cable Leaking Bad. How to fix?
Old Oct 27, 2008 | 09:29 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I replaced my TV cable. Now it is leaking BAD.Just steadily drips.
The new cable had a small thin seal already on it so I just installed it like that. I have seen two other style seals before that worked awesome.
What did you guys do to seal your cable?
The dealer is no help in looking for a stock seal.
I will try pretty much anything.
-Cale
Old Oct 28, 2008 | 07:35 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Re: TV Cable Leaking Bad. How to fix?
Anyone?
Old Oct 30, 2008 | 04:43 AM
90_WS6_Formula's Avatar
Car: 91 Z28
I'll assume (yeah yeah I know) that you mean it's leaking around where it goes into the tranny. I had one do this a couple years back. You can either replace the grommet that goes in the tranny or judicious use of RTV. You can get another grommet from any Tranny builder.
Old Oct 30, 2008 | 05:14 AM
Beggins's Avatar
Car: 1987 Trans Am GTA
Engine: 355 TPI
Transmission: 700R-4
Axle/Gears: 10 bolt limited slip with 3.42
I just had the same problem. There are 2 types of grommets a big and small one. Make sure you get the right one. i had to go to a tranny shop to get it.
Bubbajones_ya
Aug 31, 2015 12:02 PM
jackhammer
Aug 15, 2015 10:04 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
