Idea for a performance and daily driver rear end
Old Feb 20, 2001 | 03:07 AM
JPrevost's Avatar
Car: 91 Red Sled
Okay, I've been doing some reading about locking differentials and I thought up something that might turn out to be a really cool idea. There are locking differentials that are activated by an electronic signal. A flick of a switch and it's locked. It is mainly used in 4x4 but here is my idea to make it work on the street.
The basic idea is this: Mercury switchs (parallel to axles) keep the diff locked when going in a straight line but when a quick turn is "felt" the diff opens up. Does anybody see a big problem other than the latency time between the actual lock/unlock and the time of sensing a turn? Please tell me if this have been tried before and where I can find more info, phone number and all that jazz would be apreciated.
, Jon (91 RS too many mods to list)
Dale Earnhart, you have done so much, you will be missed.
Old Feb 20, 2001 | 03:16 AM
JPrevost's Avatar
Car: 91 Red Sled
I know that the AUDI A4 2.8 Quattro has both front and rear. So I guess it's not a new idea on cars but it still is something I'm curious about. Also that is all wheel drive, it's basically a 4x4 offroad system made for the road. I'm thinking rear wheel drive can use the same technology.
Old Feb 21, 2001 | 05:29 AM
JPrevost's Avatar
Car: 91 Red Sled
Bump, hello, could somebody just reply once and make me feel better.
Old Feb 21, 2001 | 05:49 AM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Sucks when no one replys huh lol? Seriously though why bother when you can just put in the Torsen differential. It basically does the same thing all by itself.
1988 Camaro
305 bored .030 over
Stock TBI
Aluminum radiator
No smog pump
gutted factor cleaner
cam ground to crane specs
timing advanced 9 degrees
no thermostat
other than that its bone stock and ran a 16.4 @ 82 mph with earth shattering wheel hop and a 2.88 60 ft time. (this was with the rebuild and cam only)
Old Feb 22, 2001 | 05:31 AM
JPrevost's Avatar
Car: 91 Red Sled
I guess but I think it would be cool to have a more tech kind of rear end. Everybody says KISS (keep it simple stupid) and I guess they're right. I would just like to see some benifits listed of having a setup like I listed.
Old Feb 22, 2001 | 06:06 PM
Blade's Avatar
The mercury in the switches is liquid, which means every little bump on the road will cause the switch to close. I dont think that would be a very viable system outthere in the real world...
Old Feb 22, 2001 | 08:21 PM
82camaro's Avatar
Car: 82 camaro SC
Powertrax will unlock and lock by allowing one wheel to spin faster than the carrier while turning. Going straight it is completely locked(none of that limited slip stuff). It has the same effect that you are looking for and is excellent for a daily driver.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
colton_carlson
Mar 8, 2019 12:21 PM
InfinityShade
Aug 22, 2015 08:00 PM
novaderrik
Aug 10, 2015 12:44 PM
