Busted 9-bolt question....
I recently had a collision with a curb in my 89 Formula. It took a chunk out of one of my aluminum rims, destroyed the disk brakes on that side and aparently bent the axle. Is there anyplace on the net or otherwise, that sells replacement axle shafts for the 9-bolt? Would i be better off getting a 4th gen. 10-bolt? My machanic seemed to think there might be problems with the brakes from a newer camaro or firebird. Is there ANY modifications that need to be made to the braking system to accomodate the 10-bolt? Thanks for your help!
J.
89 Formula Black / Grey cloth int...305 TBI / 700R4 auto...Borg-Warner 9-bolt 2.77...rear disk brakes...Nitto NT450 tires...K&N Filter...Flowmaster Crossflow...Accel cap/rotor...Accel Supercoil
J.
Hi there,
I recently changed my 9 bolt disc brake Borg/Warner rear end for a 10 bolt setup. I had ran into a problem with the rubber line that T's off from the 2 stainless brake lines that are on the axle.It seems the disc"s rubber hose has differnt fittings on it than the drum brakes.I had a post up here on the this problem but no one answered.
Tra/maro
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Mods: 3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255l walpro f/pump
Tra/maro
Mods: 3inch
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Which axle do you need?
Take a measurement and let me know. I still have one left over from a 9-bolt rear-end.
Sold the other one. It is in perfect condition.....
Raven:
I need the passenger side shaft. If you have one, let me know how much you want for it. Your help would be GREATLY appreciated
J.
J.
Engine: 5.7L
I need the measurement to be sure.... I sold one and I can not remember which one I sold. Drivers or passenger...
They are two totally different lengths.
Let me know... I want to make sure I have the one you need the first time through...
Does anyone know what the measurement is????
UltRoadWarrior9
Sep 2, 2015 08:24 PM
