Shifts late and hard
Car: 91 Z28
When the car is cold it won't shift out of first until 3K and second is pretty late too. Third shifts hard but not quite as hard. I have to fan the gas a couple times go get it to shift into 4th and lock up.
Any help is appreciated.
Car: 1987 Trans Am GTA
Engine: 355 TPI
Transmission: 700R-4
Axle/Gears: 10 bolt limited slip with 3.42
Re: Shifts late and hard
Once you find out whats causing yours to do it could you =send me a e-mail I am having the same problem with first and second gear. third and fourth shift kinda easily. Have you done any work to the tranny lately ??? Cause I just put one in from a 2wd pick up and mine started doing it.
Car: 91 Z28
Car: 91 Z28
it was air trapped behind the throttle valve
I worked the TV cable back and forth with the engine off and I heard air escaping like a long drawn out fart and now we're good to go again
now I got to figure out how the air got there
Breazlan
Sep 25, 2015 11:20 AM
TheTraut88
Sep 7, 2015 05:22 PM
dimented24x7
Sep 6, 2015 03:51 PM
