Clanking noise from right rear
Old Nov 2, 2008 | 11:07 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Whenever I was driving over to my football game today, I started hearing a clanking noise coming from the right rear of my car. It only makes a noise when I'm going through a left hand curve or turning left. If I'm driving slow I can't really hear it, but only at speed. I looked under the car and couldn't find worn spots. Any ideas?? I'm not too good at diagnosing drivetrain issues. I've thought it might be a bad bearing but it seems like it would make the noise when I turn right as well.
Old Nov 3, 2008 | 07:49 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Clanking noise from right rear
a loose tail pipe/exhaust system can make bad sounding noise . check it over good . also check track bar & brace ( AKA panhard bar ) . on my previous car i found all 3 of the panhard bar bolts had backed out and fallen away . they are the ones that secure the bar to the body on the drivers side . either one are common problem areas . good luck .
Old Nov 3, 2008 | 12:35 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
I looked yesterday at all the suspension bolts, none were missing or seemed backed out. I'll check my exhaust as well. The clanking is consistent, it sounds like an engine with a spun rod bearing.
theshackle
Sep 17, 2020 08:26 AM
Fronzizzle
Mar 18, 2019 08:29 PM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
