How much is it going to cost to rebuild my T-5
Old Feb 23, 2001 | 08:08 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
The second gear is gone for sure, how much do these typically cost to rebuild? How much if it is just the second gear and syncro?
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH 3300lbs less driver and speakers Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam.
Old Feb 23, 2001 | 08:43 PM
mikeage2's Avatar
last time i checked around here in upper il it was ~$600 for just bearings+synchros.if second gear is all ate up,chances are theres more damage to other gears as well.
Old Feb 25, 2001 | 12:44 AM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
I just had similar work done this December on my camaro. Here are the cost of the parts off the bill.
Master O/H kit: $420
1-2 Selector Sleeve: $105
2nd Gear: $196.63
Clutch Kit: $276.68
With labor it came to $1587.24
For that amount of money I would recommend looking at some other alternatives. I had an extended warranty so all I had to pay for was the clutch. I'm sure you can get cheaper quotes because the labor here was almost $80 an hour. If you have any more questions email me.
Hope this helped
Old Feb 25, 2001 | 11:16 AM
Fastcamaro87's Avatar
man for that price, u might as well buy a tremec or a t-56
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Feb 25, 2001 | 11:23 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Damn that's a lot of money. I got a price quote for 500. A tremec is only like 2000, why didn't you go with that?
Old Feb 25, 2001 | 11:39 AM
Troy 85Z's Avatar
Car: 85 Z
I agree that $1500 is way to much. I would have swapped a t56, but I only had to pay a $100 deductable and the warranty would not replace a t5 with a t56. If I didn't have the warranty I would have got a t56 hands down. Just make sure you explore all your options before you do anything. Good luck
Old Feb 26, 2001 | 09:02 PM
ev305tpi's Avatar
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
I actually just ordered my rebuild stuff for mine today. I had to get the rebuild kit which included all blocker rings, bearings, seals, snap rings, etc. That was $140. I also needed a second gear, that was $95. I needed the mainshaft outer ring syncro for 1-2 gear which was $75. And, i needed a reverse idler which came to $47. All together, it was about $370 with shipping. I am good friends with the rebuilder so the labor will probably be about $250 or so. The new clutch pack was $175, and i bought a new flywheel through GM for just under $200. The parts for the tranny i got through Hanlon Motorsports. Have any of you out there dealt with them?? How was their quality of parts?? Hope this helps out - Erik - 86 IROC-Z
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
NZKnight
Oct 15, 2015 02:47 PM
Damon
Sep 26, 2015 04:29 PM
6998poncho
Sep 25, 2015 02:56 PM
