Front seal of rear end is leaking, help
Old Feb 26, 2001 | 11:59 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The front seal of the read end is leaking slightly. To replace this seal, do I have to remove the pinion from the rear end?
Can someone give me a procedure to cure my leak problem?
Side note: The 3.70 gears whine like hell on the coast down side. I have seen that you shim the pinion more to get rid of the coast side whine. Can anyone here confirm this?
I'm wondering if I should bite the bullet and take care of both promblems at the same time.
Opinions appreciated.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
next mod: 4.10 rear gears
Old Feb 26, 2001 | 02:17 PM
82camaro's Avatar
Car: 82 camaro SC
Once the gears have 'worn-in' don't change the shims. Your wine will probably get worse if you do.
10 bolt instructions
remove driveshaft
mark nut location
remove big nut
remove yoke
pop seal out with screwdriver or seal puller
install new seal
install yoke
install big nut, tighten enough to remove any slack in the bearing(should be about where the mark is)
install driveshaft
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
[This message has been edited by 82camaro (edited February 26, 2001).]
Old Feb 27, 2001 | 11:06 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
82camaro,
Thanks for the help, I think that I will take your advice and change the seal only.
Old Feb 27, 2001 | 11:18 AM
JeffT's Avatar
Car: 1991 Z28
just so you know that is not the correct way to do this job. Notice that I didn't say you couldn't do it this way, just not correctly.
The correct way you have to remove the axles, ring gear/carrier and pinion. There is no way to establish proper pinion bearing preload while turning the ring gear/carrier. You will need a new pinion nut and crush sleeve as well.
Also, look at the seal surface of the pinion yoke it may have a grove worn in it. You should be able to get a repair sleeve from NAPA.
Old Feb 27, 2001 | 02:24 PM
82camaro's Avatar
Car: 82 camaro SC
If you put the nut back where it used to be my marking it, you end up with about the same preload. I've done lots and lots of these on all kinds of GM cars and trucks. Never had a problem. You can do it the long way, but the end result is the same. Maybe 2% of what I've seen needed sleeved. Try the seal first.
82camaro
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
