how much to get 10 bolt rebuilt....
Old Feb 26, 2001 | 03:44 PM
black84ta's Avatar
with 28 spline axles and all that other good crap?
Old Feb 26, 2001 | 04:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That depends on 3 things:
What do you have now?
What do you want when you're finished?
What can you do yourself?
ICON Motorsports
Old Feb 26, 2001 | 04:58 PM
black84ta's Avatar
10 bolt that came with car
a 10 bolt that can handle 350-400hp
nothing really
Old Feb 26, 2001 | 05:08 PM
ede's Avatar
ede
i did one last summer:
200 richmond gears
100 richmond install kit
150 strange girddle
25 mobil 1 and gm friction modifier
few dollars to weld the axle tubes to the center section and spray paint, new brake lines
if you farm it out figure a mark up on the parts and 3 or 4 hours labor
ICON Motorsports
1st & 3rd
Old Feb 26, 2001 | 06:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Add to ede's post if you don't already have them:
  • Posi or locker unit of your choice - $100 for SLP to $350 for Auburn, on up from there
  • 28-spline axles - $250 from SUperior or Moser or the like, whatever they charge for a junk 10-bolt with discs at the boneyard
  • 89-92 disc brake setup? see above
  • $65 for Steve Spohn LCA attachment point lowering brackets to reduce / prevent wheel hop
  • I paid $75 the other day to have a 10-bolt welded around the tubes, the spot welds filled in properly, and the LCA lowering brackets installed with a bracing plate; it may cost you less or more depending on lots of things, mine was totally empty and cleaned up
  • $125 for sandblasting & powder coating if you want it to stay rust-free
I would recommend using a crush sleeve eliminator which is about $25, especially if you're going to set it up yourself.
ICON Motorsports
Old Feb 26, 2001 | 10:04 PM
v6-3.1's Avatar
to EDE. what do you mean by this Quote "few dollars to weld the axle tubes to the center section and spray paint" . Do you mean that rod that holds the spider gears to the diff.
please reply
Old Feb 26, 2001 | 10:44 PM
bigvic's Avatar
This tech article should help you out. It even includes prices and links to get the parts.
www.thirdgen.org/newdesign/tech/beefinguprear.shtml
Old Feb 27, 2001 | 10:32 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What both ede and I were talking about, is where the tubes that the axles are in, plug into the center section of the housing. They're steel tubes but the center is cast iron. The factory puts 2 spot welds per tube which are weak and besides that the joints often leak. Welding all the way around them adds considerable stability to the whole system.
ICON Motorsports
Old Feb 27, 2001 | 04:09 PM
Mo's Avatar
Mo
is it possible to do the welding with the rear end still on the car?
(I am guessing no, but might as well ask)
thanks
90 IROC 5.7l (L98)
ram air, K&Ns, air foil,Flows
LIKE A ROC
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
