Opinions of Moser Axles?
Just wondering if anybody had any Moser axles made for a third-gen and whether you supplied the measurement or they had them and whether the axles were cut to the correct length.
Jason
Jason
The axles shafts aren't necessarly the weak link of the the 7 5/8 10 bolt, and that axle isn't worth putting that much money into it, IMO. Put the money for axle shafts towards a 12 bolt or nine inch. I don't know if that is the answer you were looking for, but that is my "Opinion of Moser Axles."
Just out of curiosity, has anyone had an axle shaft failure in one of these rearends?
87 IROC 350
Mods: 3:42 Torsen, pocket ported 083 heads, complete Edelbrock exhaust, Most free mods, Most little mods, aluminum d/s. Edelbrock STB, boxed rear suspension pieces, urethane bushings everywhere.
Stock cam, chip, runners, base, and trans
13.94@103mph, 2.25 60'
Recent stuff: SSM sfc's, Homemade relocation brackets, Ported SLP runners, ported base, EGR!
Current/future projects: homemade torque arm, and 27x10 Hoosiers (need wheels!), and Prom Burning
Planning new engine build, possibly 383 w/ TFS 23*
87 IROC 350
Actually I was wondering b/c I bought a pair of Moser axles and they were .040" too long. I had to do this because of my ZT posi swap. I was just trying to find out if anybody had ordered some third-gen axles from them and whether they came in the right length.
Jason
Jason
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
My Moser's were about .035 - .040 too long as well. Additionally, the OD at the end by the C-clip was also about .005-.010 to big to slip through the machined area in the HD Torsen paddle.
I got my factory 28 spline axles for $100 from a junk yard. I had to buy the whole rear end, but still cheaper than the Mosers. It was an open, drum brake rear out of a 91 firebird 305.
87 IROC 350
87 IROC 350
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
I had to replace an axle shaft because the previous owner bent one of them, I used the mosers and had the same problem of them being a little to long, we just ground a little metal off the end of each shaft.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
darwinprice
17
Oct 11, 2015 11:51 PM
