Tremec 3550 Experts w/in.
Old Mar 1, 2001 | 01:06 PM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
A friend of mine with a "Brand X" vehicle has been having problems with his Tremec 3550 5-speed trans. After only a couple of months, it started grinding into second gear. It was also hard to shift into other gears. He took it apart and it looks as if the clutch has been dragging. Anyway, a new second gear synchro assembly cost ~$200. Is there any other transmission that uses the same synchro? Anyone know of a better price? Any other suggestions? Thanks. I need him to get his running correctly so I can spank the **** out of him.
1992 Camaro Z28; Engine:383 w/Edelbrock RPM ported heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, 1.5 Roller rockers, 30 lb injectors. Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10. Super Ram.
Mo steel for Mo stremph!
Old Dec 24, 2001 | 05:01 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Even though this post is 9 months, I will add a reply.
The problem is probably fixed, but it sounds like the bellhousing was misaligned. That will cause the input shaft to keep spinning at engine speed from it being dragged along by the pilot bushing and the flywheel. The syncronizers work hard against this drag and subsequently wear out prematurely.
I hope your buddy had the bellhousing dialed in when he got the tranny rebuilt.
topteam54
Oct 6, 2015 12:21 AM
djmarch
Oct 2, 2015 10:41 PM
ASE doc
Sep 22, 2015 03:13 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
