Posi install, will i have to realign the carrier?
Old Feb 28, 2001 | 10:00 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I will be adding the SLP take off posi to an open rear. I will be keeping the same gears, just adding the posi unit. Can i just disassemble the carrier and reinstall it with the original shims or will i have to realign everything from scratch?
Old Feb 28, 2001 | 11:07 AM
82camaro's Avatar
Car: 82 camaro SC
'just the posi unit' The posi unit is the carrier. With a different carrier, adjustments will probably have to be made.
If you want to keep your gears, a powertrax is a direct swap. You won't have to remove the gears or adjust anything. Just install it. By the time you install the slp, add a bearing kit, then some labor, maybe some axles--you end up spending about the same money. The powertrax ends up having more traction, easier to install, and much less headache.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
[This message has been edited by 82camaro (edited February 28, 2001).]
Old Feb 28, 2001 | 06:19 PM
Nitro Don's Avatar
If you just swap the carrier,you'll be fine.
Shim it up the same way it came out.The shims are for adjusting gear lash tolerances,not for the carrier.
Good luck.
Nitro Don
Old Mar 1, 2001 | 12:28 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Yeah, but nitro, he can't just assume that his new carrier is going to have the exact dimensions of his old one, and thus he should make sure to check it all first.
If there weren't so many precise dimensions involved in fitting gears then it wouldn't ever be necessary to shim, as all gears should have the same height from face to teeth, and all carriers should have the same dimensions race to race and race to ring face, etc.
...ed
Old Mar 1, 2001 | 01:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Every carrier swap I have ever made without execption, if I left everything else the same and swapped teh carrier, life was good. The shims aren't there to adjust tolerance in the carrier (or the pinion either for that matter), the thing with the big tolerance is the housing.
So, as long as you have a 3 series gear now, the odds are very high in your favor that you can swap the carrier with no further effort required.
ICON Motorsports
Old Mar 1, 2001 | 05:55 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
There are variences in carrier sizes, there no way around it. I would re-assemble as-is, and check everything. This includes backlash, and total turning pre-load. To find out more about building up the 10-bolt, go here: 10 bolt
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 2, 2001 | 09:04 AM
Omega's Avatar
Engine: LS1 / LS3
Thanks everyone.
I called a local shop and they said they would swap them for me for $180-200. I thought that was reasonable concidering the set up kit was $100. I don't plan on doing this again so i am giving it to them.
Thanks again
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
knight72
Aug 10, 2015 09:32 PM
