Will a Borg Warner 9 bolt with 2.77 gears be ok with a 355 making about 400HP/425Ft??
Old Feb 27, 2001 | 09:32 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Ok, I'm finally starting my 355 engine and with the entire setup I should be pushing 400HP easy and about 425-450 ft lbs of torque!! Will my BW 9 bolt with 2.77 gears hold up??? I still have no idea why GM put such a sh*tty rear end with such sh*tty gears with nice disc brakes on an '86 TA!! That's just WRONG!! Bastards!!
1986 Trans AM
305 TPI
200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Soon to upgrade to a 350 converted from TPI to Carb, Edelbrock 750CFM Carb, Edelbrock Performer RPM Intake, Headman Shorty Headers, Some sort of ported heads (undecided), XE268 Cam, Moroso HEI ignition kit with external MSD Blaster II Coil and an MSD 6-AL Box!!
Current project: Keeping my 305 running until I get my income tax returns!
Old Feb 27, 2001 | 10:59 PM
IROCeastTN's Avatar
86, I have those same gears and yeah they suck!! But, these rears seem to be pretty strong. My car is a 350 TPI with a few mods some I don't have listed, but mine has survived many nitrous runs with a 175hp shot hitting the gas and the gogo juice on the last yellow And its still hanging around. It was running 7.40s 1/8 mile times with the juice. Some 3.70s would be really nice though! Oh yeah man I'd pick up those AFR 195s and the XE274 cam. My bro has this cam in his 85 Z-28 with ported 462 chevy heads on a 350 5-speed and it ROCKS!! He's wanting those AFRs now though, those things are MEAN!!
[This message has been edited by IROCeastTN (edited February 27, 2001).]
Old Feb 28, 2001 | 07:20 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The rear end isnt crappy, its just the gear ratio in it that is. The 9-bolt is actually stronger than the 10-bolt. You'll be fine.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 2, 2001 | 11:34 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Well sh*t then i'll just find a 3 series carrier, i figured the 9 bolt would like implode if i did a stroker or a 355.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
hectre13
Dec 11, 2023 08:14 AM
1984HO
Mar 19, 2021 11:59 AM
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
