'98+ T56
Old Mar 2, 2001 | 05:15 PM
VortecZ's Avatar
Car: Camaros
'98+ T56
Have any of you guys put a '98 or newer T56 in a third gen? I found a '99 to put in my Camaro but I don't want to change it all over to the LT1 stuff. Since the LS1 cranks are different,it looks like I could custom make an input shaft and make it work. I wanted to see if anyone else has tried this before I spend a lot of time and end up dissapointed. Thanks.
Old Mar 2, 2001 | 06:49 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
The '98-up T56 will not work in a third gen. The input shaft is longer than the '93-'97 and the bolt pattern that mounts to the bellhousing is different. An LS1 bellhousing will not bolt up to our cars. An LT1 bellhousing will. You need to find a '93-'97 (preferably '94-up due to their higher torque ratings) T56 and everything else that goes with it.
1991 Z28 - 350 TPI, T56, McLeod street clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
