What size are the driveshaft bolts?
Old Nov 9, 2008 | 10:13 AM
jcsws6's Avatar
Guys,
Real quick trying to help a friend finish a project today and there are no junk yards open/around. Does anyone know the size/thread pitch of the four drivshaft bolts at the u-joint? Hoping they are something we can grab at Lowes and be done!
Thanks!!
Old Nov 9, 2008 | 12:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: What size are the driveshaft bolts?
They're special bolts. Usually 5/16" bolts with a 5/16" flanged hex head. Try you local auto parts store.
I thought most of the GM u-joints used straps over the caps?
Old Nov 9, 2008 | 02:43 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I know we stock a few bolt/strap kit sort of deals for that at Autozone.
Old Nov 9, 2008 | 03:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Doh! Ya right. Straps AND bolts. Whenever I think of bolts, I picture solid caps over the u-joint caps held on with bolts or u-straps that go through the yoke and are secured with nuts.
Same things goes. A regular bolt won't work however an allen head bolt "may" work since it's head is smaller than a regular bolt.
It's always best to use the proper parts. Just about every auto parts store should carry a GM strap kit.
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
knight72
Aug 10, 2015 09:32 PM
