Trans Temp sending Unit
Old Feb 22, 2001 | 10:12 PM
Havoc's Avatar
I recent bought an auto meter electric Trans Temp guage where is the the best place to mount the sending unit. The trans is a non lockup 350 Turbo.
Old Feb 23, 2001 | 01:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could take the trans pan down, drill & tap it for the sensor hole, clean the pan, and put it back up. I also recall someone buying a manifold from Autometer that went between the tranny and the factory trans cooler, and held a bung for the temp sensor.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 23, 2001 | 08:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends on what they give you to mount it. The one I have is designed to mount in one of the cooler lines. You mount it in the return line. That's the upper one on the rad cooler and the upper one on the tranny.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Mar 4, 2001 | 10:19 PM
Havoc's Avatar
Any one have a part number.
Old Mar 5, 2001 | 01:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Autometer P/N 2286 for 3/8" O.D. tube, 2287 for 5/16" O.D. tube.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
