What should I do about a manual tranny
Old Nov 13, 2008 | 08:00 PM
buckshot48's Avatar
I have an 83 camaro z28, I would like to change it to a manual transmission. Is this going to be a complicated switch? And how hard will it be to find a cheap manual tranny to put in?
Old Nov 14, 2008 | 02:11 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: What should I do about a manual tranny
Aside from the sticky about how to, you didn't specify your idea of cheap. If you mean cheap, you're probably looking at a salvage-yard automatic. What did your car come with? If it came with a T5, then it had the '83-only mechanical clutch linkage, which is now pretty rare. For '84, GM installed hydraulic linkage, and continued through '92.
Old Nov 17, 2008 | 05:43 PM
buckshot48's Avatar
well camaros are new to me, It has the stock Automatic tranny attached to an lG4 engine, I'm not sure what it is. my idea of cheap will prob take me to the salvage yard. It doesnt seem like there are too many manual tranny's out there in camaros????
Old Nov 17, 2008 | 06:24 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
your ideal situation would be to find a local donor car cheap . as we all know you only find those deals when you don't need them . you will find them on this forum going from 5 to 8 hundred . i sold an entire set-up to convert a few months ago for $675.00 . do a search on conversion , find out what you are going to encounter . good luck .
Falcon50
Aug 22, 2020 03:26 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Fireslash
Apr 11, 2016 06:43 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
