T-5 making funny noise while in gear past 3000RPMS
Old Mar 8, 2001 | 09:53 PM
theformula's Avatar
Only happens when the car is at operating temperature and the tranny is warmed up enough. The clutch is brand new by the way and the tranny is the stock one.
I rev it past 3 k when in gear and the shifter handle rattles like crazy and the car makes this grinding type noise. It keeps making the noise until I put the car in neutral. And if I rev it past 3k in neutral it doenst make the noise. Could it be the synchros? Also, sometimes when i shift into 2nd it grinds.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (4700rpm limit),Holley 9mm wires,Ac delco R43ts plugs,fastchip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Mar 9, 2001 | 10:42 AM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Is it the stock shifter? Somtimes aftermarket ones will amplify any small vibrations that the stock one wont, because of there more solid design, I have seen this in a couple of cars, Otherwise I dont know..Kevin
theshackle
Sep 17, 2020 08:26 AM
BlackBoulder
Aug 11, 2015 11:15 PM
novaderrik
Aug 10, 2015 12:44 PM
BrianI
Aug 9, 2015 11:52 AM
