World Class t-5 vs T-56 Why get a t-56?
Car: 92 Formula
Transmission: A4
What are some good reasons to swap to a t-56 other that the fact that there are 6 gears to rip through instead of 5?
What are the hp/tq ratings of the t-56 and WC T-5?
And gear ratios....
(planning a 350 swap... trying to decide on a tranny...)
Thanks!
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
And gear ratios....
Thanks!
92 Rs 3.1/T-5
Clarion Head Unit,
AIM : Theonekiztope
ICQ: 8787542
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The T56 is MUCH stronger and a better built transmission. The WCT5 is rated around 305 ft/lbs, while the T56 is rated around 450 ft/lbs.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Tremec's are wicked. They bolt right in and they're very strong and tight tranny's.
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Autometer Vac+Oil Temp
89 GTA G92
Jet Airfoil
K&N Airfilter
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
the t56 also has double overdrive so you can run deep rear gears OR get much better gas mileage
Axle/Gears: 3.45, 3.27, 3.27
From Car Craft June 2000 issue: rated strength: WC T5, 3.35 low: 300 lb-ft, prod WC, 2.95 low: 305 lb-ft. Tremec 5 speed: TR-3550: 360-425 lb-ft; TKO: 375-525 lb-ft. T56 (Tremec 6-speed): rated strength: 3.35 low, 350 lb-ft; 2.97 low, 400 lb-ft; 2.66 low GM, 450 lb-ft.
Lomsal:
does it say Tremec on the side of the 6 speed? like towards the rear of the trans where the shifter mounts?
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Brandon
New project-89 IROC
tonys91rs
Oct 10, 2015 03:31 PM
Damon
Sep 26, 2015 04:29 PM
