What Spedo Gears do I need to Change????
I have a 87 Trans Am 350 TPI with a 5-spd that has 3.73 gears, My spedo is off about 15 MPH and I'm changing the spedo gears inside, What was in it was a red drive with 9 teeth, I'm installing a purple drive gear with 7 teeth, now do I also need to change the driven gear? What is in is a gray 22 tooth gear. Should I change it to one with a lower number of teeth they list a 20 and a 19 tooth gears. I would like it to be as close to the correct spped as possible but don't want it to show say 55 when I'm only going 50, 1-2 MPH over or below would be fine. Thanks for any help on this, jason
Car: Trans Am
Engine: L69
A 19 or 20 will get you real close,Depending on your tires. check this out it will give you a great calculation.
www.hanlonmotorsports.com.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your dealer should have it, if it hasnt been discontinued. If not, Hanlon should have it, or www.gearzone.net or others. It should cost <$20
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
