Should my limited slip/posi be this tight?
Old Nov 15, 2008 | 03:38 PM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Axle/Gears: Uh, Haven't investigated this yet
I just picked up a 9 bolt PBR rear today. Looks like Its got 2.77 gears . oh well. Any how. My friend and I were trying to spin the the axles different directions from each other. We couldn't get it to happen. Its almost like there is a spool in there. Its definatly not though. What are your thoughts on this.
Old Nov 15, 2008 | 07:53 PM
big gear head's Avatar
Re: Should my limited slip/posi be this tight?
Sounds like it is working like it should.
Old Nov 16, 2008 | 01:28 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
i agree, that means its doing its job well.
Old Nov 16, 2008 | 03:08 PM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Ok then. I was thinking that it wouldn't kick in to posi untill one side made a bunch of revolutions more than the other.
Old Nov 16, 2008 | 03:43 PM
its not something that really kicks in, since its always active. another way to check is to do a burnout and if both wheels spin you got a positraction rear end
Old Nov 16, 2008 | 06:30 PM
That is true with the 10 bolt Governor Lock, but the 9 bolt has a different differential in it aht is locked all the time. It will slip when you turn a corner, but it should be locked any other time.
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
