Bought a new rear end need to upgrade
Old Nov 15, 2008 | 12:44 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
I just bought a 1990 10 bolt posi with 2.73s. I want to rebuild the rear end. I bought the 1990 because I know it has 28 spline axles, Wanted to upgrade from my stock 86 open diff. My question is what ring gear size will it have or does that not matter. I am looking at this right now http://store.summitracing.com/partde...5&autoview=sku
I have a limited budget so I can't spend $500 on a carrier, This car is just going to be a street car anyway.
Any input would be great.
Wow, I just realized the part I listed is not the whole carrier, oops. What 3.73 carrier is out there for under $500?
Old Nov 15, 2008 | 03:00 PM
big gear head's Avatar
Re: Bought a new rear end need to upgrade
What you need is a gear set that will fit the differential that you have. There are special thick gears made for the 7.5 10 bolt that will allow you to install a 3.73 gear on a 2 series differential. You can install one of these on the posi that is in the 2.73 rear end that you already have.
Old Nov 15, 2008 | 03:20 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
to be safe id pull the axles out and count the splines, you shouldnt trust word of mouth when it comes to parts, not only that but did you open it up and see what shape its in?
Old Nov 15, 2008 | 06:33 PM
The 86 Rear End is whining right now. I have already payed for the 1990 10 bolt. I thought GM switched to 28 spline in late 1989. I am not gonna use the 2.73 posi. I have 2.73 gears in my 86 right now-its just an open diff. If the posi is still good in the 1990 I will use that and just get new gears in it.
Old Nov 16, 2008 | 11:28 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
im in the same boat, but i picked up an 82 saginaw rear with and eaton grenade-lock and 3.73 gears, i just advise that you visually inspect the carrier, i brought mine home and the spider gears are all chipped and messed up, there is no way im going to use it now.
Remember that if the rear had 2.73 posi it should be a series 2 carrier, meaning you can only use a certain numeric range of ring/pinion setups, series 3 has like 3.23 and up which is what i just got.
As far as the changeover im not sure because i think ive got a 26 spline axle but then again i havent pulled one to look yet
Old Nov 16, 2008 | 01:07 PM
So since the 1990 rear end is a series 2 I can't put 3 series parts in it? I Thought series 2 and 3 were interchangable.
So when I am looking up ring and pinion setups I am looking for ones that are series 2 then right?
http://store.summitracing.com/partde...217+4294776352
And would this truetrack work
http://www.jegs.com/i/Detroit+Locker...2A317/10002/-1#
Old Nov 16, 2008 | 01:13 PM
If you get the thick gears you can install them on the 2 series. These gears are made just for that reason. The 7.5 is the only rear end that I know of that has 3 series gears available for the 2 series differential. The 2 series is made for 3.08 to 2.41 gears. The 3 series starts at 3.23. The thick 3.73 gears will fit the 2 series. There are probably other ratios available for the 2 series too.
Old Nov 16, 2008 | 01:21 PM
http://store.summitracing.com/partde...217+4294776352 This is the summit 14-0041 3.73 gm 10 bolt gear combo kit for a 2 series.
Old Nov 16, 2008 | 06:33 PM
That should do it.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
