Tranny not wanting to drive in Drive!
Old Mar 10, 2001 | 04:25 PM
biotic's Avatar
Around 2 nights ago a friend called that was stuck int he mud i went to help him out and i got stuck also. When i was triong to getg out by rocking my truck no noises or nothing but on the drive hope drive wouldnt work i have a 94 ex-cab 350 auto trans. if i start out in first it will go once i hit 30 put it in drive it drives fine. now i have had a few people tell me that it may have mud in the connections or modulaer may be out but im going to clean it all out today, are these signs of shot tranny? please respond i need help only was of getting around.
Old Mar 10, 2001 | 06:43 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Since you have a '94, it is equipped w/ a 4L60-E.
Your "modular" is the PCM wich also controls the engine functions as well. I highly doubt your computer took a poop getting stuck in the mud. These PCMs are usually pretty good.
As for the connection getting mud in it, I doubt it. You could disconnect the plug, and it will still pull foward in gear (although it would be in third w/ max line pressure).
When you say "drive" I am assuming that you mean "OverDrive". There is a difference. If it will not pull foward in "OD" but will in "D", "2", and "1", and reverse works, I would say the foward sprag is broken. The reason it will pull foward in "D" and lower is becuase of the Overrun clutches appying "overriding" the sprag. Then once you get up to speed, you can put it in "OD" and it will work because the actual 4th gear does not use the sprag unlike 1st, 2nd, and 3rd.
I would get it fixed ASAP, because although it is now drivable, the overrun clutches consist of two clutches and two steels, wich is 1/3 of most other clutches. This means if you keep driving this way, they will eventually take a poop also and you will have nothing but reverse.
The sprag itself is cheap (if indeed this is what it is) but it will require removal of the tranny, and you may as well re-seal it (overhaul) and look for other worn out items.
If and when you do get it fixed, request a new Reaction Shell (aka Sun Shell) while its apart, you'll thank me later.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
hokis
Aug 9, 2015 03:57 PM
drathaar907
Aug 6, 2015 04:20 PM
