is it really necessary to get a better differential cover???
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
SLP has that aluminumone available, but do i need it? is it more for support? or just cooling? what is the deal?
i was thinking of just getting the one that they have that is like an OEM one but has teh drain plug. would this be ok? im not running anything crazy back there.
-brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - TBI, MSD ignition, SLP exhaust
700R4 - 2,400 stall converter, vette servo
10 bolt - coming soon - SLP zexel torsen differential, GM 3.73s
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
it keeps the rear end from flexing under loads, and that cause broke parts. it's worth it if you launch your car hard, it also increases the lube capacity and helps cooling. i think i read it increases strength by 40%.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Get one that has the bearing cap preload supports. It will have small bolts and jam nuts on the back. These keep the carrier from trying to push the bearing caps out the back of the diff.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Anyone have any idea who makes a differential cover for the 9-bolt rears? I'd like to get something nicer than the stock one. Thanks for any help!
Duck_Hawaii
87 IROC-Z5.7
92 Z28-5.7 Anniversary
Duck_Hawaii
87 IROC-Z5.7
dbrochard
Sep 19, 2015 08:13 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
