Non 3rdgen Question
Old Mar 9, 2001 | 05:44 PM
Bort62's Avatar
Non 3rdgen Question
A girl I Work With has a 97ish Jimmy.
She is Very attractive ( side note ~ )
Its got a 5spd Manual ( I think 5, I didnt pay that much attention )
Anyhow, It grinds into reverse the magority of the time. All other gears are fine.
Pedal travel feels Fine. When Putting the Shifter into reverse, with the clutch depressed, If it dosent grind I can feel interferance.
Anyone willing to hazard a guess ?
It has a hydraulic clutch, the fluid level looked fine, But looked Dirty.
Thanks In advance.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Mar 9, 2001 | 06:12 PM
vortech305's Avatar
Gears are grinded. It seems the tranny will need some rebuilding. U didnt say how many miles were on the tranny. And since its a females jimmy, they dont really know how to drive 5-speeds, no matter what they say. She grinded her gears. Tell her to get an automatic.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 9, 2001 | 10:37 PM
The ODB's Avatar
don't worry about that it's harmless.
you can drive forever with it like that.
Old Mar 10, 2001 | 12:04 PM
Bort62's Avatar
haha, Yeah I figured ODB, but how Do I fix it and therefore, getinto her pants ?
Thanks for the replies guys.
Old Mar 10, 2001 | 09:49 PM
84FTA's Avatar
I don't know about Jimmy's but they probably suffer the same 'disease' mentioned here many times (also seen on Mustangs, Jeeps, S10's, ect) is a lightly syncroed reverse gear. Try putting it into first and then reverse. That interference you feel is the (ack! at a loss for techincal terms)...well...tailshaft is locked by the brakes, and it can't go into gear is basically what happens. If you let of the gear or go into first and put it into reverse while rolling it goes in easy. I usually end up having the "interference" in reverse every morning.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 Trans Am T-tops
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Mar 10, 2001 | 10:53 PM
chevyboy07 91's Avatar
Well, to get into her pants.....you'll prolly need a jimmy. I think it will come in handy LOL
Old Mar 13, 2001 | 11:39 AM
BigChevy342's Avatar
Yea i have the same problem with my 5-speed in my p/u, i just shove it in first or any other gear before i put it in reverse but if im still moving slightly and put in first or whatever and then reverse it will grind. So you just have to be completley stopped
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
