what is a boost valve?
Old Mar 12, 2001 | 10:01 PM
rondubbs's Avatar
i see that people put this on when they put a vette servo in. what is it and how hard is it to install?
Old Mar 12, 2001 | 11:00 PM
82camaro's Avatar
Car: 82 camaro SC
Increases pressure in the tranny. The .5 aftermarket boost valve is the one you want. It's right next to the pump inlet. One snap ring holds it into place.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Mar 12, 2001 | 11:12 PM
rondubbs's Avatar
how hard is it to install? how much is it? where can i buy it?
Old Mar 13, 2001 | 07:56 AM
82camaro's Avatar
Car: 82 camaro SC
Just a quick price check:
TCI-374301 23.69 from summitracing.com
With the tranny pan off, it's about a 10 minute job. Good snap-ring pliers really help.
82camaro
Old Mar 13, 2001 | 09:50 AM
rondubbs's Avatar
Old Mar 13, 2001 | 10:46 AM
rondubbs's Avatar
would this in conjunction with a vette servo give me nice firm shifts from first to third gear?
Old Mar 13, 2001 | 06:07 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
A .5 boost valve for $9.84 from:
http://www.hptransparts.com
It's under g/m 700r4 valve body kits.
The corvette servo kit is only $9.41
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Mar 13, 2001 | 08:23 PM
82camaro's Avatar
Car: 82 camaro SC
I figured somebody had it cheaper. It's a simple part. .5 boost valve and vette servo in my otherwise stock 4.3L tranny from an astro van yields wheel spin when shifting.
82camaro
Old Mar 14, 2001 | 12:07 AM
rondubbs's Avatar
thanks a lot guys..
im assuming that this kit has the vette servos and boost valve too??
Servo kit & boost sleeve, 700-R4
#HP35952-K servo kit, accumulator piston and boost sleeve Corvette style servo
#HP35952-K...$18.19
Old Mar 14, 2001 | 09:49 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
<font face="Verdana, Arial" size="2">Originally posted by 82camaro:
</font>
Maybe a dumb question, but in wet (rainy) conditions, do you have any problems with the wheels spinning too much (uncontrolled), or does it shift "safely" if you keep your foot out of it? I'd be a little concerned about it in wet weather...
KAM
Old Mar 14, 2001 | 10:37 AM
82camaro's Avatar
Car: 82 camaro SC
Driving a third-gen in bad weather you have to be careful anyway. The hard shift just adds to it a little bit. You get used to it. It's no different than a shift kit.
82camaro
Old Mar 14, 2001 | 06:56 PM
JoelOl75's Avatar
That kit has the accumulators in it for a rebuild. The hole gets elongated (aluminum on steel) and the piston ****s and leaks. Causing a sloppy shift. Just get the servo and reverse the accumulators like this.
Take the 3-4 accumulator out of the case. Put the spring in 1st. Flip the piston over.
Do the same to the 1-2 accumulator. So the pistons are flipped and next to the seperator plate. This effectivly renders them useless and hard shifts will result with no more leaks. Of course there are many ways to do this. B&M shift kits use solid spacers, but with fluid pressure on the far side it doesn't matter. You can tap the holes (not with trans in car!) and tie them with a piece of hard line.
There are holes to drill bigger in the plate too.
Old Mar 14, 2001 | 07:48 PM
rondubbs's Avatar
<font face="Verdana, Arial" size="2">Originally posted by JoelOl75:
</font>
say what?? i have no experience with trannies at all,.. and i dont understand what you said.. i think you told me not to get the kit, just the vette servo, right? what about the boost valve?? ill let the pros install it all, i want to drive my car this summer,, unlike last when my intake project went south and the car sat for 5 months
Old Mar 15, 2001 | 02:39 PM
rondubbs's Avatar
bttt
Old Mar 15, 2001 | 05:06 PM
Pro Built Automatics's Avatar
I carry the .500 main boost valve, .296 intermediate/reverse boost valve, and the Corvette servo. The total price for the package is $45.00. If I can help call me at 800 7763288 Mon-Sat 10-6 PST.
Glad Too Help!!!
Old Mar 15, 2001 | 07:23 PM
JoelOl75's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ron rizzotti:
say what?? i have no experience with trannies at all,.. and i dont understand what you said.. i think you told me not to get the kit, just the vette servo, right? what about the boost valve?? ill let the pros install it all, i want to drive my car this summer,, unlike last when my intake project went south and the car sat for 5 months </font>
Ummm.... Yeah, don't get the shift kit. Get the servo, boost valve......
The accumulators are little flat pistons in the valve body. One is on the outside (1-2 shift) and the other is directly under it inside the trans case (3-4 shift) They essentially 'cusion' the shifts against a spring. By taking the spring out, then taking the piston out. Then put the spring in first, then flip the piston over and put it in next. Both springs are up against the seperator plate. When you are done, the pistons will be next to the plate. They will no longer cushion the shifts. This is all most shift kits do, but you should do the servo and boost valve too. The 1-2 accumulator has it's own cover next to the valve body and is actually not connected to it. It's a snap to do and the pistons come right out with two pairs of needle nose to grab it (don't pry them out with a screwdriver or you'll damage the bore) You'll need to remove the valve body to get the other acc. though. Just remember to get the pistons near the seperator plate, and flip them over. It's like a mirror image thing.
'88 Camaro RS 2.8L
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Doobie52
Sep 11, 2015 06:19 PM
tgp1990
Sep 4, 2015 06:24 AM
