I'm trying to put the drive speedo gear back on the output shaft on a 700r4. There are 2 holes that the gear clip will fit into. Do I use the front hole or the back? This is for a elect speedo. Thanx
Front hole. The rear hole is for c4 vettes.
Thanks!
Tags 700, 700r4, clip, front, gear, hole, holes, location, needed, output, put, r4, shaft, speedo, speedometer, transmission
- Aftermarket guage cluster custom 87 TA
- 86 T-top IROC-Z LSX Iron 408 LS3 Built t56 sell or trade as roller spohn bmr umi
- [CA] 85-92 FIREBIRD 140 ELECTRONIC SPEEDO FOR SALE (92065)
- Swapping to an open element air cleaner assembly on 85 Berlinetta 2.8l V6
- Will a speedo drive from T5 digital work with a Super T10?
