Is my throwout bearing the prob?
Old Mar 16, 2001 | 07:03 PM
formula14's Avatar
First of all i just put a new centerforce dual friction clutch in my car. I put a new throwout bearing in and immediately it started chirpin and clattering when the clutch was in. Now if the clutch is in, it makes whizzing noises in my transmission. If i let the cluth out and push it in real fast the whizzing goes away for a few moments than returns. The clutch works great but sometimes when i let it out it makes a quick whizzing noise. Why would my throwout bearing go bad in 600 miles? what precautions should i tale when i put a new one in? Thanks.
Old Mar 16, 2001 | 07:35 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
If you used too much anti-s. it can do that as well. allowing the bearing to slip instead of spinning with the presure plate
Old Mar 17, 2001 | 12:10 AM
BigChevy342's Avatar
Maybe you got oil on the flywheel or pressure plate or the clutch? did you change your pilot bearing?
Old Mar 17, 2001 | 01:32 AM
formula14's Avatar
Yes we did put a new pilot bushing in. I had some oil leaking out of where my oil pressure sender goes in the block. I dont know if any of that could get up and in there. The t/o bearing was from autozone and i think maybe they gave me a non self aligning one. could that have been the problem? i really dont want to replace one every 600 miles
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
customblackbird
Oct 1, 2015 04:30 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
