Is this the right info on my differential??
Old Mar 14, 2001 | 05:24 PM
RICHRAD's Avatar
The stock rearend in my Trans Am is a 10-bolt. Am I safe to say I have a 7.5 ring and pinion with 26 spline axles. Also If I change my open to a posi does series 2 or 3 matter anymore.
Old Mar 14, 2001 | 07:00 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
What year T/A is it? I think in '85 GM went from the 7.5 to 7.65. Also, if its pre '89 then its a 26 spline.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 14, 2001 | 07:08 PM
RICHRAD's Avatar
ooops !! Tried to get it up there too fast I guess. It's an 86.
Old Mar 15, 2001 | 05:07 PM
RICHRAD's Avatar
aw man, I think I've been this route before .Just trying to figure out what I think I might have as a rear now. Should have known, If there's anything that draws a blank on this website , it's REARENDS!!
Old Mar 15, 2001 | 05:35 PM
RICHRAD's Avatar
Excuse me, I gotta grip now! One more question though. I thinking of purchasing a GM 7.5 posi w/26 spline and 3.42s. Will this go in my 10 bolt housing if it is presently a 7.625 ?
Old Mar 15, 2001 | 06:36 PM
82camaro's Avatar
Car: 82 camaro SC
the only thing different is the ring and pinion. You case will work just fine.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Mar 15, 2001 | 11:28 PM
RICHRAD's Avatar
Thanks GMTech, 82camaro . Bought this afore mentioned unit tonight on the web.Hope the thing installs okay. Do you think I'll notice a considerable difference over my 2.73 open rear? Even with a stock lg4?
Old Mar 16, 2001 | 09:00 PM
RICHRAD's Avatar
Anyone done this along with lg4 mods??
Old Mar 16, 2001 | 09:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
One of my little brothers used to have one, he went from a 3.23 to a 3.73 from a L69 car. Made a HUGE improvement but it still was far slower than my L69.
If you have a 2.73 in there now and the posi carrier is a 3-series, it will not work. The flange for the ring gear will be about ¼" too close to the pinion. If however it is a 3-series (more likely) you can stick a set of 3.42s in there. Your axles are 26 spline, so as long as the carrier is 26 spline (more than likely it is) you'll be OK.
ICON Motorsports
Old Mar 16, 2001 | 10:12 PM
RICHRAD's Avatar
I think I have a 2 series right now with the 2.73. I thought that ( series ) didn't matter as long as the 7.5 posi unit has a matching ring and pinion. Two and three series all fit the same 10 bolt housing don't they?
Old Mar 17, 2001 | 03:25 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Yes, the carriers are interchangable. Just make sure the ring&pinon match the carrier. Some aftermarket gears are matchined thicker so you can bolt a 3 series type gear on a 2 series carrier; but with stock gears you have to get a matching one.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
3rdgenparts
May 21, 2016 11:50 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
