bolt patterns for tranny
Old Mar 17, 2001 | 02:47 PM
Mr.LOSER's Avatar
I have an 89 iroc with a 350 tpi that the tranny went out on, I've been calling around to get a tranny from a junk yard for it but no one has one for a 350. I asked someone why a 305 th700-r4 wouldnt fit and he said the bolt patterns were different. Would i be able to drill new holes to be able to bolt up one from a 305? and I was also thinking about buying a 5-speed set up but a web page i went to said that 350's diddnt come with a 5-speed because of emission problems, so woulndt i have to make new holes for that to if i could?
stock 89 Iroc tpi
Old Mar 17, 2001 | 03:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They're probably talking about the flex plate. The 305 should have the small flex plate and the torque converter bolts from a 350 won't line up. A dual bolt patter flex plate will fix that problem.
As for bell housing bolts, All SBC have the same bellhousing bolt pattern.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Mar 17, 2001 | 08:10 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
no the 350 and 305 700r4 are excactly the same same converter same fly wheel. the only thing I would do is get one from an 88 and up 3rd gen although caprices will work too they use differant springs and possiably differant shift points.
Old Mar 17, 2001 | 09:06 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
the 91-92 700R4's are alot stronger than the older ones so i would go with one of those
1991 banditt2 #130 of 600
Project 350 Banditt
<A HREF="http://clubs.yahoo.com/clubs/streetdawgracing" TARGET=_blank>
http://clubs.yahoo.com/clubs/streetdawgracing</A>
http://y42.photos.yahoo.com/tonysams72.
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
Jorlain
Oct 8, 2015 01:57 AM
billybob6110
Sep 23, 2015 01:30 PM
Stryker412
Sep 7, 2015 09:11 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
