Auburn Gear mini spools
Old Mar 18, 2001 | 07:20 PM
jester731's Avatar
has anyone used this instead of posi rear? i saw it in jegs and it says it "locks the axles together for even power distribution to both rear tires" and it only costs around $100's which is a lot less than a posi any feedback would be appreciated thanx
Old Mar 18, 2001 | 09:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
To my knowledge they don't make one yet for 28 spline axles. Only 26 spline. By locking the axles together they will both turn the same speed. Not a good thing for a street car. When turning a corner with a regular differential either open or posi, the outside wheel turns faster than the inside one. When the axles are locked the outside tire can't turn as fast and will skid across the pavement.
Mini spools are mostly designed for dirt track racing where tire slippage isn't a concern. Dirt track cars also use different tire sizes on each side.
Mini spools are weak and won't survive the abuse of drag racing. Full spools aren't available for our tiny 7.5/7.625 differentials since they are not performance diffs.
That leaves only a few options. Get a Torsen diff from SLP, spend the money and buy a real posi or buy something like a LockRight PowerTrax
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
db057
Apr 28, 2019 07:45 AM
dbrochard
Oct 3, 2015 12:43 PM
64goatman
Sep 9, 2015 01:09 PM
Fronzizzle
Sep 8, 2015 12:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
