Kickdown cable????
Old Mar 18, 2001 | 07:06 PM
Metallica383's Avatar
Kickdown cable????
Ok I installed a 700r4 out of a car with 30,000 actual miles the car was wrecked so I bought the tranny when mine died well the tranny does fine dont slip or nothing but I dont know if I may have strectched the kickdown cable or something cause I cant quite get the shifting right it dont want to shift in 1 and 2 gear until it gets to high RPMs or when it hits the high RPMs if you let of the gas it will shift then in over drive it bogs way down before shifting back down to 3rd gear I have tried the adjusting of the cable and I have put probably 4,000 miles on it in this condtion like I said never has slipped the first time so I really think that it is in this cable although I am no expert That is why I am asking.
Thanks for any help
Old Mar 19, 2001 | 12:21 AM
idrag2's Avatar
How did you adjust your cable? I had a prob. like that with mine and it was in my 1-2 accumaltor and my servo.......but it may very well be a worn out cable, hope this helps?
Old Mar 19, 2001 | 02:27 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What kind of car is it out of? Was it fuel-injected and your car is carbed? Different TV springs were used for those applications which might cause your problem.
Old Mar 19, 2001 | 04:17 AM
I had my brother hold the button down while I pushed the gas pedal to the floor. yes this went into a carb car and came out of a fuel injected car what can I do to fix this?
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
