Is it posi? Can I get powertrax
Old Mar 18, 2001 | 11:31 PM
IROCZ88's Avatar
I just got a 9 bolt disc brake rear out of an 86 TA. It has 2:77 gears. How can I tell if it's posi by taking the cover off? If it's an open rear, can I get a powertrax locker for it. Anyone have a link to there webpage? Finally, can I use the ebrake cables for a drum brake rear on a disc brake rear?
'88 IROC TPI 355, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp Roller Rockers, Comp Cams TPI cam, fully ported '90 speed density TPI with '86 base so it fits older style heads, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
Won bracket races at Numidia Raceway with my '70 Nova
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
Old Mar 19, 2001 | 09:48 AM
82camaro's Avatar
Car: 82 camaro SC
It's a 9 bolt, so your options are very limited.
try www.powertrax.com
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Mar 19, 2001 | 08:06 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
hold the driveshaft yoke still and turn one wheel. if the other wheel turns the other way it not a posi
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
