SWAP THM-200-R4 INTO THM-200
Can I use a THM-200R4 out of a 88 pontiac or an 89 buick station wagon in place of my 82 Camaro 305 with THM-200? Is this a bell housing no-no? Do I need cross-member changes or other modifications? Do I change TVI cables or driveshafts or anything else?
1966 c10 panel
1968 c20 350, 350
1982 camaro 305, th200
1966 c10 panel
1968 c20 350, 350
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
you need to see if the 200r4 has two sets of holes in the bellhousing.if there is only one set of holes it will not bolt up to the chevy engine.ive been told the 200r4 and 200 are the same length so the driveshaft should interchange
I thought that all 80's station wagons were fwd.
If not fwd, it will work if the car that your taking it from is a 4.3 or bigger. 2.8 and 2.5 motors use different bellhousings although the guts are the the same.
85 Camaro RS 350/350 stealth intake, holley street avenger 670
true dual exhaust. "ButtStang killer"
82 firebird 305 all original - the cat and smog crap."All show No go"
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Most 200-R4's have two bolt patterns one is chevy. They are the same length so drive shaft fits, tranny mount is farther back so you will need a new crossmember (maybe TTA)
TV cable is the same use yours. Plug and play have fun. 8^)
Don>>>
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Don>>>
'92 CAMARO RS
B4C Alt.
Hello, Michael
Aug 20, 2015 03:19 PM
