shift kit or servo?
Old Mar 18, 2001 | 04:41 PM
daniel dekay's Avatar
shift kit or servo?
this week is finals week, that means next week im able to work on my car. i have a garage at home so im gonna do all the routine maitenence and what not. i have been reading alot of posts regarding corvette servos, and shiftkits.
my question is what would be a better mod for my situation. check the sig for mods, i wanted a shift kit but i have seen some negative posts regarding BM shift kits, some mixed results with Transgo shiftkits and various positive results with corvette servos. should i go with a servo or a shiftkit, or both? i have novice mechanical skills so please keep that in mind.
thanks
daniel
86 camaro cpe(dont laugh)has 92z28 body kit with GTS covers, new red paint and a killer stereo. 2 amps, 8 speakers, disc changer, custom install with subs coming by the end of the summer. gm 350,TES headers, flowmaster cat back, performer manifold, TCI converter, jet chip, kn with dual snorkel cleaner. and she still passed the sniffer!
"Cal Poly SLO is the shi#"
Old Mar 18, 2001 | 07:59 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I would definatly go with a servo and .500 tv boost valve. You can do these without dropping the VB and the results are better imo.
Old Mar 21, 2001 | 01:18 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
BTTT.
Looking For:
87 IROC-Z28 350 TPI: The car I want.
84 TRANS AM 305 H.O.: Another car that would be OK to own while I look for the IROC-Z!!
[This message has been edited by IROCZTWENTYGR8 (edited March 21, 2001).]
Old Mar 21, 2001 | 01:52 PM
whats BTTT?
Old Mar 21, 2001 | 04:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you get the "consumer grade" TransGo kit, I believe it comes with the Corvette servo.
Old Mar 22, 2001 | 12:33 AM
Administrator
I moved your post up again so it could get more responses, I think its a good topic.
Looking For:
Old Mar 22, 2001 | 05:43 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
BTTT = Back To The Top
And definitely go with the Trans-GO shift kit. I am on my second one. I had the Stage I and just upgraded to the Stage III.
Definitely do not get the B & M one...
Talk to Dana at Pro-built tranny... He will be able to help you out... He has Awesome customer support...
www.pro-built.net
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
raven
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
scottmoyer
Sep 7, 2015 07:06 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
