Differential
Old Mar 22, 2001 | 01:31 AM
robert1's Avatar
Differential
How can you tell if a carrier is 2 series or 3? It's an Auburn unit from an '89 IROC.
Old Mar 22, 2001 | 08:13 AM
89BlwnRs's Avatar
What gear ratio did it come with? If it was above 3.08 from the factory than it's a 3-series carrier, 3.08 or below is a 2-series carrier. If it has aftermarket gears, you can't tell that way. Richmond I know makes all gears for either carrier.
Jason
Old Mar 22, 2001 | 10:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The difference is the location of the ring gear flange. It you set it on end with the flange at the lower end, a 2-series one will have the flange about ¼" lower than a 3-series one. I don't know the exact dimensions though. If you can find a known ne to compare it to, it should be obvious.
ICON Motorsports
Veaceonee
Sep 29, 2016 08:15 PM
dbrochard
Jan 28, 2016 08:42 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
dbrochard
Sep 19, 2015 08:13 PM
