Missing Cross Member bolt need suggestions
Car: YTG Camaro
Engine: 383
Transmission: TH-350
A while back I swapped the 700R4 and replaced it with the TH-350 tranny. In the process of doing so the welded in nut from one of the cross member (CM) bolts broke and the bolt was spinning all by its self. I have since cut the bolt out and have been running with 3 ever since.
I will be installing a Spohn TA with a new CM soon. I would like to fix the CM bolt issue now due to the signifance of its use as the TA mounting location. Any suggestions on what the best way of fixing this is welcome.
'84 Camaro w/ Large Jouranl 327 bored .030 over; 3.73 geared Auburn Limited Slip Diff. FlowMaster Muffler w/ Shortie Headers. TH-350 Built Trany Underneath B&M Mega-Shifter. Many Engine compartment Dress Up Mods. Edelbrock High Flow Water Pump w/ Flex-a-Lite Cooling Fan.
It is still under construction @ www.iserv.net~brodgers
Car: 82 camaro SC
Have a nut welded into the subframe.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Transmission: 4L80E/4L80E
I just slid a nut/washer inside the frame for the back two crossmember bolts ('82's didn't have TH700's). I had to punch an additional hole in the back of the frame rail to get them in (held with a box-end wrench), but other than that, no problem.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Car: YTG Camaro
Engine: 383
I tried to get up in the sub frame with a wrench and had too much trouble. That was two years ago I'll try it again this weekend.
My only concern with welding the a nut in the frame other than the welding part is lining up the nut to the bolt. Maybe I can get a shop to do that for $10. I do not have a welder.
hectre13
Dec 11, 2023 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
mhatfield 14
Oct 24, 2015 07:48 AM
