4th gen rear
Old Mar 24, 2001 | 03:36 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
4th gen rear
I have heard you guys talk about ho the 4th gen rear ends bolt up with little/no modification. How hard would it be to put a rear from a 99Z with 4.10s on my car. I have rear drums, the new rear has disc brakes. What all is needed to do this swap? I know the new rears are about an inch longer on both sides, so what would be the correct backspacing to run so my wheels didnt stick out? Also, how much power do you think it can take? It has a torsen posi, G2 girdle, and LCA relocation brackets. Thanks!
[This message has been edited by Scott_92RS (edited March 24, 2001).]
Old Mar 25, 2001 | 12:19 AM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
The tech page on this site has an article about this swap. Everything should bolt up just like your factory axle but the 4th gen year is 2" wider per side. Sorry but I'm not sure what back spacing is correct. I'm using 99SS rims with mine. If you check out slp on the web they could probably tell you what you need to know about offset.
Old Mar 25, 2001 | 02:00 PM
Scott_92RS's Avatar
Car: 1992 RS
Thanks, I should have checked that out in the first place! It doesnt have any info on the drum-to-disc conversion, though. What all will be needed to do the swap? Can I use my exisitng master cylinder with a new proportioning valve? Thanks.
Old Mar 26, 2001 | 01:56 AM
kermit_one's Avatar
Scott, i put a 4th gen in my car going from drum to disc.The mastercylinder is the same but you need to change the proportioning valve.I used one out of a 92Z from thirdgenparts.Direct fit and works great.
92RS,POLO GREEN
Old Mar 26, 2001 | 02:19 AM
jobryan26's Avatar
This may sound stupid but can anything be swapped on the frontend from 4th to 3rd? I mean since your changing the rearend and gaining disk brakes and they're are 2" wider per side. Can the A-arms, spindles, front discs, and etc. be swapped also. To widen the same as rear and have better front brakes? Anyone tried? Just curious
'87 Trans Am:
(Engine)
305 TPI
160 Degree Thermostat
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment
(Stereo)
Kenwood Excelon
Old Mar 26, 2001 | 09:40 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
No, the front suspension is setup differently, but I ask myself if there's a way to swap to 4thgen front brakes on my original frontend everytime I pull the wheels off of those things. They look sweet! Anybody know?
Old Mar 26, 2001 | 11:57 PM
jobryan26's Avatar
I like the Idea. Larger front disc brakes!
'87 Trans Am:
(Engine)
305 TPI
TB Bypass
Accel Super Coil
(Stereo)
Kenwood Excelon
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
