How many quarts does a T5 take?
Old Mar 23, 2001 | 04:23 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I put in 3 is that ok?
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, B&M Ripper shifter, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, all bushings are urethane, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH 3300lbs less driver and speakers Next mods-> Extreme Energy 268 cam, Holley street dom intake.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, gutted air box.
[This message has been edited by JDMZ28 (edited March 23, 2001).]
Old Mar 23, 2001 | 06:57 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Did it take 3? that seems like too much to me, but I don't remember. I was thinking it was under 2. pull out the plug on the side and fill it until it comes out.
That's brings me to another point altogether. since our T5's are slanted we're actually overfilling them a little...right? not that the few extra millimeters (milliliters) of fluid should make much difference. I build gearboxes for road racing cars. the theory there is don't put in too much or you'll cause excess heat. of course, too little will cause heat too. oh well, go with the plug thing.
Clem
Old Mar 23, 2001 | 11:44 PM
Fastcamaro87's Avatar
what year is it?
Old Mar 23, 2001 | 11:52 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
d
Old Mar 24, 2001 | 02:51 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
It's an 86'
1986 CAMARO Z28 ->
1987 TRANS AM ->
Old Mar 24, 2001 | 04:53 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
1.5 quarts ATF
Old Mar 24, 2001 | 11:39 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I used ATF last summer when I did the clutch and when I pulled it 3 weeks ago it was purple. My trans man told me to use Gear oil, it has something to do with the syncros. I'm sure that's not a big issue though.
I keep getting different answers on how much to use, my local auto parts store told me to add 2, others tell me 2.5,and 1.5. I have no idea. I put in about 2.75 and have had no problems. The one thing I have noticed is a little whine while in 5 gear, only under pressure (while under acceleration and deceleration). I highly doubt that has anything to do with over filling though.
I think I'll put it up in the garage and pull the plug. The reason it might not have drain out when I was filling it might be because I poured it in by the shifter, it might not have worked it's way down until I drove it around. If I pull the plug and nothing comes out I'm not going to worry, it can't take more than 3 quarts. I also vaguely remember it taking about 3 last time I filled it. Thanks guys
1986 CAMARO Z28 ->
1987 TRANS AM ->
Old Mar 27, 2001 | 09:15 AM
84TransAm's Avatar
ATF and Dexron 2 or 3 are the same right?
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Old Mar 27, 2001 | 12:13 PM
leirch's Avatar
From what i understand, pre 88 meaning 87-back used gear lube, 88+ used ATF.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Hotrodboba400
Dec 10, 2019 07:07 PM
abray1
Sep 14, 2015 08:18 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
Navy8125
Aug 17, 2015 01:29 PM
