GM Upshift Kit
Old Mar 22, 2001 | 06:02 PM
NightHawk's Avatar
GM Upshift Kit
I recently bought the GM upshift kit for my 700R4. The thing is, it doesn't come with any instructions. I really wasn't going to do it myself, but I was wondering if mechanics know how to put this thing on? After all, how often would they install such a part? Thanks for any replies.
Old Mar 22, 2001 | 10:57 PM
v6-3.1's Avatar
I also have this part, people recomend them but no one really knows how to put the pieces,I have a good guess but I dont wanna risk it without it being correct
Old Mar 22, 2001 | 11:09 PM
v6-3.1's Avatar
check out this forum , you will see to what im refering to.I do not know how to link so just clip and paste.
https://www.thirdgen.org/messgboard/...ML/001161.html
Old Mar 22, 2001 | 11:20 PM
v6-3.1's Avatar
this site here has a couple of diagrams of the tranny please nave a look at it
v6-3.1's Avatar
this site here has a couple of diagrams of the tranny please nave a look at it.
http://www.transonline.com/totalTechDatabase/index.html
Old Mar 23, 2001 | 06:55 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Actually I was wondering the same. That backtrack link and every link to it explains NOTHING!
It says remove the tv cable, then no dont....
I ordered mine and it didn't arrive yet, I probably figure it out but some pre-info would help me too...
Old Mar 23, 2001 | 03:12 PM
NightHawk's Avatar
hey... maybe the Tranny Doctor might know something about this... anyone know how to get a hold of him???
Old Mar 23, 2001 | 07:18 PM
v6-3.1's Avatar
btt
Old Mar 23, 2001 | 11:44 PM
EDDIETA_ZZ3's Avatar
Car: Trans Am
Engine: ZZ3 HO
Transmission: 700R-4
Hi, I saw this post and I must tell everyone that I'm completely happy with the kit. Like all of you I had no clue how to install the kit but I was fortunate to do it myself after obtaining the instructions from B&M. First of all, If I would do it again I would suggest also installing a Transgo shift kit because you have to remove the valve body. Second, the kit doesn't replace the TV cable nor is it altered. The kit includes a new boost valve for the trans pump. The new sleeve, red spring, and piston replace the stock 3-4 shift valve located at the front part of the valve body (behind the Torque convertor). I must warn all of you that most difficult part was installing the boost valve. Make sure its seated in its bore with a new snap ring. I hope that helps all of you.
Eddie
Old Mar 24, 2001 | 12:13 AM
Car: Trans Am
Engine: ZZ3 HO
Thanks for the link V6-3.1
Folks here it is! Replace your 3-4 line shift sleeve and piston with your new GM kit 3-4 valve and piston. Looking zig zag from left, replace the second valve with the fourth valve here's the pic
http://www.transonline.com/electroPu...m?pageID=1602.
Don't forget you MUST install your new boost valve that comes with the kit!
Eddie
Old Mar 24, 2001 | 12:19 AM
Car: Trans Am
Engine: ZZ3 HO
And here is a pic on how your new boost valve is installed. Look at left side.
Eddie
http://www.transonline.com/electroPu...fm?pageID=2439
[This message has been edited by EDDIETA_ZZ3 (edited March 23, 2001).]
Old Mar 24, 2001 | 02:41 AM
JoelOl75's Avatar
Arg. Simple..... I know there's six parts to the assm. Plunger, alm. sleeve, spring, a valve, and 2 roll pins. (87 1/2 earlier theres a alm. sleeve for the vlave too)
I have the parts right in front of me, but never rec'd the new parts from gm yet. The link had me more conf'd than.....
(especially the part with the tv cable delete)
Thanx from me, hopefully someone can answer the other ? i posted tonight or i'll have to call......
Old Mar 24, 2001 | 04:19 AM
v6-3.1's Avatar
basicall replace the late 3-4 line up with the pices from the kit??
then open the pressure regulator and replace the other pieces??
please reply!!
Old Mar 24, 2001 | 12:53 PM
Car: Trans Am
Engine: ZZ3 HO
Yep, that's basically it other than installing a new tranny filter and pan gasket.
Good luck,
Eddie
Old Mar 24, 2001 | 02:54 PM
NightHawk's Avatar
Is this for the GM kit, or the B&M kit? I got the GM kit. I'm asking because you got the instructions from B&M. If it is the GM kit... I really appreciate the help... thanks.
Old Mar 24, 2001 | 11:39 PM
Car: Trans Am
Engine: ZZ3 HO
Yes it is for GM part # 8673948
B&M also sells a kit that not too many people know about. It's part B&M # 70249.
This not so well known kit B&M sells is exactly like the GM kit. The well known
"TV sleeve" B&M's bigger seller (probably most here have seen it) that is sold in Jegs and Summit is a total P.O.S!
Trust me, I have all three in my rides and I installed them myself. The last one I mentioned, the cheap TV sleeve, is in my Astroturd. It doesn't allow a full throttle 3-4 upshift and when you hit the gas to the floor while crusing at 85 hehehe a violent downshift occures. Therefore, get GM kit or ONLY B&M # 70249.
Eddie
Old Mar 24, 2001 | 11:55 PM
Car: Trans Am
Engine: ZZ3 HO
REMINDER!!!!!!
BE SURE TO STUDY THE CHECK BALL LOCATION ACCORDING TO YOUR YEAR TRANSMISSION. CHECK OUT THE LINK 3.1V6 PROVIDED. BE CLEAN AND WORK IN A CLEAN ENVIORMENT. THIS MEANS SWEEPING ANY DIRT OFF YOUR CONCRETE DRIVEWAY!
ASSEMBLE ALL PARTS ONLY WITH PETROLIUM JELLY AND NOTHING ELSE, IT'LL MAKE YOU LIFE A LITTLE EASIER!
Old Mar 25, 2001 | 04:54 PM
NightHawk's Avatar
Thanks man... I really appreciate it.
Old Mar 26, 2001 | 01:37 PM
NightHawk's Avatar
One more thing...
It said on the web page about the PR & TCC valve line up that some "lands" must be ground off. Is this really necessary to make the kit work, or is that part for something else? Thanks again
Old Mar 27, 2001 | 07:35 AM
JoelOl75's Avatar
It's a good idea to grind them. It allows more oil to the planetaries and balances pressures which could result in pump ring breakage (common on older pumps with cast rings)
Old Mar 27, 2001 | 10:41 PM
NightHawk's Avatar
But grinding them off is NOT a necessity, right?
Old Mar 28, 2001 | 07:00 AM
JoelOl75's Avatar
No, but it's simple and pretty much free insurance. It's more of a higher rpm thing.
Old Mar 28, 2001 | 06:55 PM
tranny doctor's Avatar
If any one needs instructions on the 3/4 WOT kit contact me and I will be happy to supply instructions. F.C Racing Transmissions by the Tranny Doctor
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
