Trying to make sure its broken.
Old Dec 13, 2008 | 11:35 PM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
Transmission: 700-r4 with no OD :(
A couple of weeks ago i was driving my 91 RS kind of spiritedly down my road and the worst thing happened. My gauges all froze, but mainly, my tranny wouldnt shift into OD afterwards. It had never had problems before, and i dont see why it wouldnt shift into OD due to me bieng WOT in 3rd. I checked the fluid its still redish-pink, and it doesnt smell burnt. No metal bits or anything in it either.
So should i be looking at flushing the tranny and hoping i get OD back?
OR
Rebuilding it/getting another tranny?
Old Dec 14, 2008 | 03:43 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Trying to make sure its broken.
it shouldnt shift into 4th at WOT. what should happen is you should let off a bit and then itll go into fourth. is that whats happening?
Old Dec 14, 2008 | 10:57 AM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
Nah, i read my original post, and i could see i worded it kind of wrong.
After my original run( bieng WOT in 3rd), when i let off, the car didnt go into 4th/OD as it usually did. Ever since then i havent had OD and my guages are frozen.
Old Dec 14, 2008 | 11:15 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Please name the gauges that are frozen, and what they're stuck at.
I'm thinking that maybe the ecm lost power or a speed signal so that it doesn't provide lockup anymore, and that maybe that is what you are experiencing as no 4th.
Old Dec 14, 2008 | 11:54 AM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
The tach is tached out(though it never worked anyway). The speedo was stuck at 80, but has since dropped to 0. Oil pressure is at 45 psi, the volts are at 0, and the temp guages is maxed out.
My aftermarket gauges still work perfectly btw.
So what causes this problem and how can i fix it?
Thanks for the quick answer also!
Old Dec 14, 2008 | 10:33 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Sounds like an electrical problem...
Old Dec 15, 2008 | 10:13 PM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
my main concern isnt the guages. its my lack of OD.
Old Dec 15, 2008 | 10:28 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i doubt it will work, but disconnect the batt over night to reset the ECM
just a thought, but it sounds like an eletrical devil on you gauges, maybe a converter not locking up
but if its really in 3rd and not going to overdrive (like said it may be the converter not locking up) then its probably some trash or some crap hung up in the valve body, servo or what not
Old Dec 15, 2008 | 10:48 PM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
OK. ill give that a try tonight.
Im beginning to become scared that my tranny really is giving out. I was testing it out today, driving around. It was in 3rd and i went WOT but the tranny didnt downshift. I throttled it in and out and it finally downshifted, but it didnt feel like it used too. The revs were up but the car wasnt moving as quick as it used too.
Old Dec 16, 2008 | 03:52 PM
89RS_82Z's Avatar
sounds like what happened when mine went south, like it was slipping in OD
i cracked my drum and also had a TV cable broke, so one took out another
Old Dec 16, 2008 | 06:18 PM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
Im actually not going to worry about this anymore, I just sold the car for $1000 with an extra 700r4 tranny. But anyway thanks for all the help guys.
Last edited by lovemymaro; Dec 17, 2008 at 12:19 AM. Reason: Sold my Camaro today!
Old Dec 17, 2008 | 12:46 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
wiring doesn't make a difference on this trans. You should get fourth gear regardless. you can disconnect the wiring four pin connector and still get fourth gear. again no wires shift this trans it is all done with the governor and valve body/tv systems hydraulically. no fourth a lot of times is a burnt band or band drum cupped and the band not holding. Otherwise known as smoked! The band in this trans is a 2-4 band. If you look at a range reference chart for this trans you would find that in second gear the forward sprag helps second but doesn't help in fourth. if you manually shift into second the o.r. clutches also help second hold. Fourth doesn't have a lot of help mostly just the band, forwards, and 3-4 clutches. Probably the 3-4's are on their way out also if the band is smoked.
Old Dec 17, 2008 | 05:52 PM
89RS_82Z's Avatar
hmm must not love your maro like the s/n suggests
BTW i would call the cops, that guy stole your car and put a spair 700r4 in it when he stole it........you could of got alot more, if it looks as good as your signiture suggests and it had good miles and a nice intreior you got raped. i was just offerd 3k for mine as it sits, rear end out and a dent in drivers door (new rear end will be home saturday and the dent gets fixed soon after its back on the road and then a new paint job granted im all matching low miles and extra clean also)
Old Dec 17, 2008 | 11:44 PM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
LOL contrary to what it says, im actually a Firebird guy (Dont tell anyone )
I know I really could of got more.. Kind of screwed myself because the guy contacted me right before i got the new transmission(for free). Car was also primered, so no paint on it. But in order to not be a jerk, i went ahead and gave him his chance to buy the car, and he came through. Eh, you live and you learn right.
Now im looking for a Trans Am/Formula!
Old Dec 18, 2008 | 05:30 PM
89RS_82Z's Avatar
heck even with primer he got a good deal
good luck on the search!!!!!!
Old Dec 19, 2008 | 03:21 PM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
Ive been thinking about building a Turbo V6 Trans Am..Might be in the future
Old Dec 21, 2008 | 02:29 AM
ed o's Avatar
Axle/Gears: 3.36
Why not a 8cyl.? It'd probably be faster. No replacement for displacement especially with the 8cyl turbo'd. I run a centrifugal supercharger but wish I had a big block or turbo. Maybe a six with turbo would be faster than my combo 11's is pretty slow with a v8 and supercharger. Boost at 12psi.
Old Dec 21, 2008 | 08:12 AM
1brd2brd3brd4's Avatar
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
RPM's are a replacement for displacement. If your statement was true.......(as many believe it is) a small block could never beat a big block. Then you factor in power to weight bla bla bla bla.........Be different, be an underdog. Remember the buick grand national. You know the sedan that was faster than the vette in the 80's......
Old Dec 21, 2008 | 03:10 PM
89RS_82Z's Avatar
a grand national now thats a car i would LOVE to have right now
Old Dec 22, 2008 | 12:17 AM
lovemymaro's Avatar
Car: 1991 Camaro Rs
Engine: 305 TBI
Im going with a V6 because I want to be a bit different this time. My 91 was a 305 V8 with headers, Intake, and a little head work and it was satisfying. But I just feel like going a different route.
Grab a V6, rebuild and strengthen it, add the turbo kit, nice turbo cam, and some other odds and ends..Then rev the hell out of it and ride!!
A GNX would be a super sweet ride, id love the drive one of those. Or at least get my hands on the motor
Bubbajones_ya
Aug 31, 2015 12:02 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
