Would it be really bad to use a 3.08 posi with 3.42s in a 10-bolt?
Old Mar 31, 2001 | 02:51 AM
Dan87IROC-Z's Avatar
I'm buying a used 10 bolt from a friend along with a set of 3.42s from Richmond. The problem is the rear end has a 3.08 posi and I don't want to spend another $400 to get a 3.23+ posi. So my question is, will using the 3.08 posi be that bad?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Mar 31, 2001 | 07:23 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Will it even fit? Sounds like you have a 2 series carrier trying to hook up with 3 series gears.
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Mar 31, 2001 | 08:18 AM
82camaro's Avatar
Car: 82 camaro SC
He is buying 2 series 3.42's from richmond. It will work just fine. I've been using 3.73 2 series for a long time. The 2 series 3.42/3.73's are just thicker than the 3 series.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
F-body driver
Mar 6, 2023 11:44 AM
dbrochard
Oct 3, 2015 12:43 PM
toyotekk
Sep 7, 2015 06:36 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
