Gears
Old Dec 16, 2008 | 06:14 AM
Twitch RS's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
Transmission: 700 R4
Gears
I am looking for more low end torque and I am willing to sacrifice a little bit of top end as long as I can still drive on the highway (60-70 mph) without being through the rpm roof...
what gear set am I looking for?
Old Dec 16, 2008 | 06:33 AM
kcb37's Avatar
Re: Gears
I do belive you will want a 3.42
Old Dec 16, 2008 | 08:38 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Gears
Stay with the 3:23 stock set up. You don't make enough power for any gear change. Save your money for other mods. Also a gear change is not a DIY job and is expensive with parts and labor. If it is not broken , leave it alone.
Old Dec 16, 2008 | 10:03 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Gears
Unless he means just swapping in the entire rear end. That would be easier. As far as gears are concerned 3.42 (10 bolt) and 3.45 (9 bolt) are about as big as you are going to want to go with a relatively stock setup. I have a mildly modded 305 and the 3.42 was just a bit more than i wanted on the highway. I dropped it down to a 3.27 and its much nicer all around. As the other person above said, best of both worlds would probably be a 3.23/3.27.
Old Dec 16, 2008 | 12:46 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Gears
guys, he already has 3.42s if it's a 3.1/700R-4 combo. The best bet is a 3.73:1.
Old Dec 16, 2008 | 03:10 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Gears
No point in modding a v6. Leave it alone and dont waste your money.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
