BOP engine to T5 transmission bellhousing
Is there a factory or aftermarket bellhousing or adapter plate that would allow a T5 transmission to be bolted up to an engine with the BOP bellhousing bolt pattern? I have a '84 T/A LG4/T5 drivetrain that is going into my new '82 T/A but at some point I'd like to install a real Pontiac engine.
Re: BOP engine to T5 transmission bellhousing
McLeod makes a modular bellhousing that will supposedly allow you to bolt any trans to any engine.
http://www.mcleodind.com/application...L_HOUSING.html
Pac J
05-17-2020 10:44 AM
adapter, bell, bellhousing, bellhousings, bolt, bop, bopc, engine, housing, pattern, plate, pontiac, t5, t56, transmission, transmissions
