TRANSMISSION COOLER
Old Mar 31, 2001 | 01:13 PM
4SPEED's Avatar
TRANSMISSION COOLER
SINCE THERE IS SUCH LIMITED AIRFLOW ON AN IROC I WAS WONDERING WHO MAY HAVE INSTALLED TRANSMISSION COOLERS, WHICH ONE THEY USED AND WHERE IT WAS LOCATED
Old Mar 31, 2001 | 05:52 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I have not gotten one yet but i am mounting it directly to the radiator
Old Apr 1, 2001 | 04:07 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
I don't drive an IROC, but I put mine directly on the radiator, dead center. Front side.
DR Stevens
1984 Trans Am 305HO L69
sucks gas, hauls ***
1991 Firebird 305 LO3
for days when I need a/c
Old Apr 2, 2001 | 07:51 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
I've got a trans cooler in my 86'berlinetta.Mounted it directly to the radiator,a little to the passenger side.I bi-passed the rad-trans cooler ,so i think my car actually runs cooler now.Before this,i used the old air conditioning condensor(hows that for recycling ?)That worked pretty well too.But my car is only driven in the summer,so i wouldn't recommend this as the trans might not get up to opperateing temperature when it's cold.
Old Apr 2, 2001 | 09:32 AM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
B&M Supercooler #70255.
Mounted to the support rods in front of the A/C condenser coil (in front of radiator)
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
Old Apr 2, 2001 | 09:50 AM
FastBroker's Avatar
Above poster is right. If you bypass the radiator tranny cooler enirely and run a nice extrenal tranny cooler infron tof the radiator, the trans will never get warm and start to collect moisture in it. It is best to keep the radiator cooler somewhere in the path, believe it or not, as it acts as a "warmer" in winter and a "cooler" in summer, as long as your water temp is around 185 or so.
EDIT: BTW, I run the Perma-Cool Engine Oil THermostat in my tranny cooling system instead of using a radiator coolant tank. It bypasses 90% of the ATF from the external cooler (ie, goes right back into tranny) until it gets to 180deg and THEN starts letting more ATF into the external cooler. REAL nice here in the Northeast and with lockup tranny because, oherwise, fluid will NEVER warm up!!!
[This message has been edited by FastBroker (edited April 02, 2001).]
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
apie2546
Sep 20, 2015 01:03 PM
scottmoyer
Sep 7, 2015 07:06 PM
apie2546
Sep 5, 2015 07:40 PM
