Can my TH700 handle it??
Old Mar 27, 2001 | 11:35 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I'm building a AFR 195 headed 383 with some other mods( se sign.). Can my Th700 handle the torque and Hp? If not what should i do about it? I'm planning to get a Vigiliante convertor but what more should I get?
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods, a AFR 195 headed 383 in the works!! ready May 2001...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Mar 29, 2001 | 08:49 PM
Pro Built Automatics's Avatar
If the transmission is in stock form?, then it won't last much longer in most cases. If you are looking for a street/strip or road racing transmission I can help you out. Call me at 800 7763288 Mon-Sat 11-7 PST, and I will do my best to answer any questions you might have concerning your transmission and torque converter needs.
Glad Too Help!!!
Old Mar 29, 2001 | 08:58 PM
Oh, by the way if you already have the Vigilante torque converter, then running it in front of the stock trans might help prolong the life of the transmission. The 9.5" Vigilante is somewhat lighter than the stock 12", thereby transmitting less shock to the gear train.
More Info!
Old Apr 2, 2001 | 02:35 PM
Pimp Daddy Welfare's Avatar
Man, GTA,
I did what you are talking about and my transmission didn't last but about 3 months. \\and when my tranny went, so did my motor, I threw a rod when it overrevved. end of story.
"LIFE BEGINS AT 140mph"
92' Firebird, modified to look like 89 formula 350, 91-92 composite aero-wing, 4-in cowl hood. 16/8 High-tech turbo rims. 355 4-bolt, Forged steel crank and rods, Forged aluminum 9.5:1 pistons, AFR aluminum heads, .510/.510 lift cam, aluminum roller rockers, chromoly pushrods, Rhodes lifters, remote oil filter kit, Derale oil cooler, Flow-Kooler reverse flow water pump, fluidamper, edelbrock air-gap intake, predator street carb, 7-quart oil pan, headers, 3 in exhaust, flowmaster,ect.
Future plans: NOS, roll-cage, slicks, ATI-procharger.
Old Apr 2, 2001 | 05:31 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
Mine took a **** 3 months later too.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Old Apr 2, 2001 | 09:09 PM
KW87GTA's Avatar
To be honest, I'm surprised your trans has lasted with the setup you have on it, let alone putting this 383 in. According to John Lingenfelter, but I do not quote; GM made these tranmissions to be very versatile and can handle over 400hp, however, they were not meant to take more than about 350lbs of torque and therefore the stock setup takes the car right up to that. The better convertor will help life, but you should really have a good rehaul done on it with much better cluthes and the like. Also a shift kit will help let it live a little longer too. If you don't feel like having the work done, you can always buy one from B&M, Hughes, or TCI and they will handle much more. Good luck. If you don't beat on it it might last much longer, but who here doesn't want to "drive" their car.
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed IAC, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
1992Z28!
Nov 19, 2015 07:33 AM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
roysatikas
Sep 22, 2015 08:15 PM
apie2546
Sep 20, 2015 01:03 PM
