What is the winding noise when I let off the gas in the rearend mean???
Old Mar 20, 2001 | 09:56 AM
86IROCMIKE's Avatar
Like in 2nd and 3rd,the whining is really annoying,its not loud just there,is something wrong????
86 IROC,canary yellow(originally black),fully loaded.305TPI WITH 700R4/SHIFT KIT,3:73 POSI REAR,4 WHEEL DISC BRAKES,T-TOPS,POWER LOCKS,POWER WINDOWS,TILT,CRUISE,SADDLE INTERIOR,POWER ANTENNAE,SPOILER OFF 87 IROC SO NO THIRD BRAKE LIGHT ON ROOF,16" BY 8" RIMS OFF 89 IROC,3"INCH EXHAUST WITH A 2 CHAMBER FLOWMASTER AND 3 1/2" BY 18" LONG CHROME TIPS,20% TINT ON SIDES,HATCH AND T-TOPS,GTS TAILLIGHT COVERS,AFTERMARKET FOG LIGHTS,PIONEER 180 WATT CD RECIEVER AND DETACHABLE FACEPLATE,WITH JENSON SPEAKERS ALL AROUND,TALKING RADAR DETECTOR"BACON ALERT"
....Long live the EIGHTIES!!!and my love for the IROCZ
Old Mar 20, 2001 | 11:18 AM
SUPER-SPORT-CHEVY's Avatar
Kinda hard to tell what is wrong. but service the rearend and see if there is any broken pices in the axle. It probably just needs some fluid. but a full service couldent hurt
85 Camaro RS 350/350 stealth intake, holley street avenger 670
true dual exhaust. "ButtStang killer"
82 firebird 305 all original - the cat and smog crap."All show No go"
Old Mar 20, 2001 | 11:27 AM
Biochem's Avatar
Car: 2002 SOM z28
Mine does that too... not a big deal really if you only hear the whine when you let OFF the gas and not when you are ON the gas.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Mar 20, 2001 | 12:58 PM
pimpintheRS's Avatar
i have heard richmond gears whine are any of you using richmond gears i see you have 3.73's in your rear...
Shawn
Old Mar 20, 2001 | 04:55 PM
jm91rs's Avatar
My richmonds have always whined too. I was told most just do that. It isn't too bad, you get used to it.
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows
Old Apr 2, 2001 | 10:13 PM
KW87GTA's Avatar
While it is true that some sets of Richmond Gears whine, it is only the pro gear sets that are supposed to, or at least that's what someone at Richmond told me. The cause is most likely a setup that is a little off. The gear lash is most likely a bit off, the louder the whine the more the lash. If this has been going on for a while you will almost definitely need new gears not merely a new setup. This lash also will decrease gear life and likewise you will go through gears quicker.
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed IAC, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
corey8084
Sep 17, 2015 02:56 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Randomtask2
Sep 7, 2015 05:06 PM
