Can a non-posi rearend do a 2 wheel burnout?
Old Dec 19, 2008 | 10:18 PM
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
Ok, maybe a stupid question but im pretty sure i dont have a posi rearend. Jack the car up and can only spin 1 wheel by hand, RE code comes to an open diff 3.42 (6 cyl). Every time ive done a rolling burnout i only leave one black mark, but the other day i did my first dead stop burnout and left 2 long black marks from first and i could tell where i shifted to 2nd (5spd T-5) it when to a single black line. So the question stands, can a non posi rear leave 2 black marks, and how?
Thanks guys!
Old Dec 19, 2008 | 10:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Can a non-posi rearend do a 2 wheel burnout?
You "may" have a gov lock diff. Spinning one wheel it will appear to be an open diff. A gov lock works when one wheel starts to spin, the diff will lock up. Although for street use on wet or snow covered which will work fine, a gov lock diff isn't very strong and it's common to break the locking mechanism.
Pulling the diff cover and having a look inside will determine if it's an open diff or a gov lock.
Old Dec 19, 2008 | 10:57 PM
heff17's Avatar
Car: 89 Camaro
but wouldnt the gov lock "lock" up when im doing a rolling burnout? Say when im rolling along at 20mph and a spank it in 2nd it will only spin one tire, it will spin it hard, for 100ft, but only one tire.
Old Dec 20, 2008 | 07:16 AM
big gear head's Avatar
A Governor Lock will not lock up when the car is moving. The governor has a weight that moves out of position when the car is moving that will not allow it to lock up. It is a safety feature that is built into it.
A standard differential can also spin both wheels if traction is close to equal between the tires.
Old Dec 20, 2008 | 10:14 AM
CJG1987's Avatar
Car: 1983 Trans Am
Engine: 305 4bbl
Axle/Gears: 10 Bolt 3.27 posi
If the traction is almost equal you can burn both tires. My 4th gen would do that all the time. On a perfectly flat surface i would roast both tires in an open diff all the time.
Old Dec 20, 2008 | 12:56 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Does anybody have a picture of a gov-lock?
Old Dec 20, 2008 | 12:58 PM
AlkyIROC's Avatar
Car: 87 IROC L98
http://rides.webshots.com/album/55410292AnMJrE
Old Dec 20, 2008 | 01:17 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
So that is the posi that the camaros came with from the factory? Are they any good?
Old Dec 20, 2008 | 04:09 PM
This is the Governor Lock
The Governor Lock is not a high performance differential. It was designed for trucks in the late '60s and is still being used today, in trucks. It was installed in a few 3rd gen Camaros, but I don't recommend it for high performance use. It has too many small parts in it that will break.
Old Dec 20, 2008 | 06:01 PM
1brd2brd3brd4's Avatar
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
enough throtle dump the clutch and you spin both tires. It happen some times with an open diff. being a V6 car I'm sure thats what you have.If no one has ever been in the diff. It would have a tag on it from GM reminding you to use Limited slip additve
Old Dec 20, 2008 | 06:24 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
it IS possible to shim an open differential so tight that it will act like a posi. Used to do it to 9" Fords all the time. On flat surface- power brake would spin them both. And off the line both would spin. But in a turn the inside would always spin...
I'd be kinda tough to do to a 10 bolt because of the way it's made. But a 9 bolt with the split carrier it'd be easy.
Old Dec 20, 2008 | 08:50 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
yes its definetly possible, i use to have a 4cyl s-10 and i fabbed up a GTP supercharger intake n stuff to fit on it, and i could spin it hard enuf to were it would lock and "break posi" as i would say, its possible
Old Dec 20, 2008 | 11:28 PM
heff17's Avatar
Car: 89 Camaro
Yea i would say it was highly unlikely that anyone went into mine and put a posi in it since it was a v6 car when i got it.
Old Jun 24, 2011 | 10:14 PM
Cody's86Camaro's Avatar
Car: 1986 SC Camaro
Engine: 305/holley
Axle/Gears: 3.42 10 bolt
i just put in a 3.42 gear in my posi and like it but so far i have only one tire spining. i read somwhere that if you lift your car up and spin one wheel that if it spins the same way its a posi if other way its open diff. mine is posi and they spin diff ways?
Old Jun 24, 2011 | 11:21 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Not a posi. At least not a working one. $0.02
Old Oct 30, 2016 | 07:04 AM
Benerb1's Avatar
I did this with my open diff the other day. For a second I thought I had a posi. I had to do some research to make sure.
Old Oct 30, 2016 | 04:54 PM
1987L69's Avatar
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
I have found out if your turn left while spinning an open diff the left tire will start to spin as well. If money is short and you have a good stick welder, you can always give it, what I call, A "Lincoln-locker". If you take this route be warned! both wheels will always have power going to them all of the time! IE taking a turn one tire will always chirp! If you do it correctly, and keep the heat only on the spider gears, it will live a long and happy life!
Old Oct 30, 2016 | 06:21 PM
Why do people keep recommending this crap? That stuff is dangerous and should never be used in anything but a dirt track car. It should never be used on the street!
Old Oct 30, 2016 | 07:12 PM
1987L69's Avatar
Car: 1984 Z28
it is not dangerous if you know what you are doing as a driver, My friend and I drove several cars in the past with this set up, just know how it acts and know what and what not to do
Old Oct 30, 2016 | 08:43 PM
That's not what I'm talking about. Welding on a heat treated gear makes it brittle. With C clip axles if the gear breaks then the axle will come out.
Old Nov 2, 2016 | 05:47 PM
clubber's Avatar
Car: '92 RS
Engine: 5.0TBI
Transmission: TKX
Eats tires and is WAY unpredictable in the rain while turning.
Old Nov 2, 2016 | 06:26 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
note and old trick to get a car or truck unstuck [ mud, snow ] you drag the brake while pressing the gas to get both tires to dig over just one.....
Old Nov 8, 2016 | 10:53 AM
keykey's Avatar
Car: 1988 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH700R4
Axle/Gears: 3.27 9-bolt w/ Torsen LSD
The reason this often happens when you do a brake stand but seldom when you do a rolling burnout is because when you do a brakestand, the wheel brakes act as the locking/clutch-mechanism.
Hard to explain if you don't know how a differential works, but if you do it's easy to understand.
In an open diff, the wheel with the least traction will always be the one that starts spinning, and if you brake both the wheels hard with the discs/drums, both wheels will have very good "traction" (friction against the discs/drums from the brakes applying) and both will start spinning.
That's also how "eLSD" (electronic Limited Slip Diff.) works on modern cars, if one wheel starts spinning (on an ice patch for example), the HECU (Hydraulic/Electronic Control Unit) applies the wheel brake to the slipping wheel, and the power will be directed to the other wheel.
Abubaca
Nov 5, 2016 12:22 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
punkmaster98
Sep 8, 2015 09:45 PM
Amillionoh7
Sep 5, 2015 11:44 PM
