What exactly does the TV cable do?
Old Apr 4, 2001 | 12:54 PM
bleak's Avatar
On an 85 TA with L69... when the TV connector is pulled forward (towards the front of the car) or otherwise, what exactly does it change in the tranny?
Old Apr 4, 2001 | 03:14 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
When the cable's pulled forward, out of the adjuster, you drop the line (fluid) pressure inside the trans. This gives you softer & earlier shift. The shift is softer because the fluid pressure is lower, and since the pressure's lower, the clutches slip more (instead of engaging right away). That's how 700r4's burn up.. over the years, the cable slides forward, drops line pressure, burns up clutches, etc...
Adjust the cable so more of it's inside the adjuster, and you raise line pressure. You won't be able to raise it too much, because as soon as you floor the gas, it will "readjust" itself to the proper adjustment.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 5, 2001 | 07:22 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
The TV replaces both the modulator and the kickdown switch/cable. If it just controlled kickdown there wouldn't be so many blown trannies because many T350 veterans assume you can leave it off and it will be ok.
Old Apr 5, 2001 | 08:49 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
It plugs into the back of the television and brings a broadcast signal to your tuner. This is usual provided by an outside company for a monthly fee. Benefits usually include, better reception, more channels to choose from, and movies.
LOL! Sorry I couldn't resist and work is really boring.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Apr 7, 2001 | 06:44 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
<font face="Verdana, Arial" size="2">Originally posted by 3RDGENFRANK:
</font>
ALLRIGHT SMARTASS! Ha ha ha!
Old Apr 7, 2001 | 10:58 PM
82z's Avatar
82z
The tv cable controls 3 things, shift points, kickdown and tv boost pressure. Proper adjustment is critical for proper operation.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
