TH350 in 92 Camaro
Old Apr 1, 2001 | 10:11 AM
bradkeith's Avatar
TH350 in 92 Camaro
I have an 92 camaro that i am getting ready to drop a 406carb'd motor into. I have a th350 that has been rebuilt,and has a long tailshaft on it. Has anyone on here done this swap? I know i can use a 82 200c driveshaft and a torque arm adapter out of jegs, but do i need a different crossmember? I really like to get things going!
Old Apr 1, 2001 | 12:32 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The Hurst T400 adapter kit (from Jegs) includes a new cross member, so I would think the T350 kit also does. Unless, it is only needed for the t400 swap and not the t350 swap.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon )
www.koolmeister.com
Old Apr 1, 2001 | 12:56 PM
ede's Avatar
ede
for about 75 dollars you can get the torque arm adapter from b&m (pn 30299) that has an adapter for the cross member too
ICON Motorsports
1st & 3rd
Old Apr 1, 2001 | 04:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Or you can spend more money and buy one of Steve Spohn's torque arm kits. It will include the proper crossmember and the new torque arm mounts to the crossmember instead of the tranny. It's a good investment.
Your driveshaft will be a direct bolt-in with the long tailshaft TH350. You need the 200c driveshaft if you use a short tailshaft TH350. The shaft will be 3" longer.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
[This message has been edited by Stephen 87 IROC (edited April 01, 2001).]
Old Apr 2, 2001 | 01:07 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Wait a minute! Do u have a 700 tranny in the car now? If so, why not use it ? The 350 tranny is cheaper , the torque converter too, but what I'm getting at is, if u put any type of performance gears in the az of your car, U will hate it on the highway!! 373 with a 350 tranny will have u buzzing along at 60mph at about 3000rpm. Thats a lot of wear & tear on your new motor!! U know something, with the speed limit in some places 65-70 mph your motor is going to get used up pretty darn fast son!! Try to deal with the issues of the 700, because in the long run you'll probally be glad that u did!
njdaewoo
P.S. been there , done that & hated every minute of it! Gears & 350 trans suck on the highway!
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 liter h/press. walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
Old Apr 3, 2001 | 10:51 PM
wolfie's Avatar
For about $25 you should be able to locate a crossmember from an 82 camaro. These had the metric tranny and have a crossmember which bolts directly to your subframe (the forward holes) and accepts the 350TH tranny. Just completed the project myself and everything bolted up perfectly. Good luck.
Old Apr 4, 2001 | 02:06 AM
mtx28's Avatar
dear goodness keep the 700, i have a 400tranny in my 74 camaro and at least 373 gears(guy i bought it from didnt know what they were, and i havent taken the time to figure it out) and i dread driving on the highway now, the motor just screams. i mean, if you really want a 350.. go for it, but i advise otherwise
  • 83 Z28--ttops, 200k miles--very ragged out. sold, thank goodness
  • 74 Z28--slightly modded 383, TH400 tranny, not too quick but fun to drive
Old Apr 5, 2001 | 12:07 AM
86Tra/maro's Avatar
mtx28> I've tried to tell him, I just hopes he listens!
Old Apr 7, 2001 | 11:20 PM
1986TransAm's Avatar
They are right about the 350/400 thing....If you plan on driving the car on the street, keep the 700R4. However, the TH350 IS stronger, so, if your going to drive it on the srtip, use the 350.
Call up Next Gen, 800-921-9214,they hae all the parts you need for the swap.
I think the parts you need will cost around $100. That includes a new torque arm bracket, cable brackets, vacumm lines, and hardware. For a TH350 swap you use the stock crossmember.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
