Using a two peice seal flexplate on a one piece motor?
Old Dec 30, 2008 | 01:08 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I can get a good flexplate cheap from a friend for a two piece seal engine, but mine is a one piece. Can I use it?
Old Dec 30, 2008 | 03:53 PM
Shagwell's Avatar
Car: projects.......
Re: Using a two peice seal flexplate on a one piece motor?
No. The bolt pattern is different and his won't have the proper counter weight.
Old Dec 30, 2008 | 09:36 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Ah yes the internally balanced vs external.
Old Dec 31, 2008 | 08:29 AM
Shagwell's Avatar
unless his is a 400 flywheel, they're both internally balanced. The one-piece rear seal crank does not have a conter-weighted flange, thus they put a weight on the flywheel. They are still considered an internally balanced engine.
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
